Question about Sanyo Heating & Cooling
Hello, I have a sanyo ac model # xs3622, c3622 and was wondering if there is a heat setting. I live in a warm climate and have never needed the heat. The remote control has a heat setting but when I change it to heat it still blows cold. Any help would be helpful. Thanks
  • 2,133 Answers
Your a/c model is only cool, but remote may be heat and cool which normally supplied by all manufacturers. Don't worry. In your remote heat mode will not respond by unit. Helpful advise?
Posted on Jan 03, 2011
Testimonial: "Thanks for the quick response. Very helpful."
2008 Honda Odyssey license plate bulbs
Hello fellow Ody owner. Ok, here's what you do, make sure it's a warm, or even better, a hot day outside. Warm plastic is your friend, and cold plastic will break on you almost always. So, if you live in a warm climate, wait for a hot day to do the job. If you don't live in a warm climate, get the van in a warm garage and use a hair dryer or heat gun (set on low) and warm those little bulb housings up a little bit. Next use a small flat head screwdriver and CAREFULLY pry the housing that houses the bulb out of it's cavity. This is done from the outside of the vehicle and there's no need to take plastics off the door from the inside. Once the housing is off, the rest is self-explanatory. Remember to never touch a bulb with your fingers as the oil from your fingers will create a hot spot on the bulb and shorten it's life significantly. This is a rule that pertains mostly to halogen bulbs, but a rule best to follow with all bulbs. Use a small piece of paper or clean cloth to handle and install the bulbs. Good Luck! You got THIS!
~SteveAlaska
Jan 30, 2017 | Honda Cars & Trucks
In the morning when 1st starting the car, the climate control does not work
If the climate control is on "auto" there is a delay before starting. For 15 minutes it is either freezing cold outside or needs repair. Depending where you live. Well anyway a way around the delay is to go to a manual setting and the system should start blowing right away.
Of course if it hasn't warmed up yet the air will be cold!!
Track the temperature gauge on the dash. As the temperature lift's off and approaches normal range heat should be coming from the vents,
New cars that are super efficient are very slow to heat up. The old gas gushers had plenty of heat to spare
So if you think it is cold where you live heck out the videos,
Cold start RAM 2500 at 35F 37C Fairbanks AK
Subaru Winter start up 44c
Jan 09, 2016 | Cars & Trucks
When front air is on rear heat always
If you have owners manual check that your climate control settings are as you expect them to be, if that makes sense. Some on Fixya do not realise they gave climate control , they think they have normal A/C and try to correct chimerical problems. Please check and repost
Jul 03, 2015 | 1997 GMC Savana
Warm up time on a Troy-Bilt cultivator
I have a Cub Cadet 4-cycle cultivator and it takes a while to warm up as well. I assume that is the norm for those small 4-cycle engines. But it should not take more than 3-5 minutes to warm up enough to go ahead and start tilling. Unless of course you live in a fairly cool climate. In that case it may take a little longer. I live in Tennessee.
May 09, 2015 | Troy-Bilt TB146 EC 4-Cycle Garden...
Why is my AC compressor running when my temperature control is set to heat, fan control set to 2, AC control switch off and air flow control set for floor?
If you have an automatic climate system where you can set temp the the compressor will run at some of the middle settings. The system blends cold and warm air to obtain the desired temp setting. If it does not have automatic control you have another issue.
Oct 23, 2014 | 2003 Mitsubishi Galant
When my car warms up the heater blows out warm but gradually gets cooler and cooler after about 10 min. It will stay cold ( about three degrees above outside temp.) It does this on cold days. And after you...
It may be the valve that controls the amount of water entering heating core but I'm wondering if your engine thermostat isn't stuck open. This is what controls the coolant temperature in your engine. It closes off while engine is off. It will remain closed after you start your car until the water warms to a certain temperature then it starts to open enough to keep your car at the proper operating temperature. If it stick open then it will take a lot longer for the engine to heat up and on smaller cars might never heat up enough for your heater. If you live in very cold climates such as where I live in Wyoming, we have to change to a higher degree thermostat so we have a good heater when it's 30 below zero.
Be very cautious here but one way you can check this is to put a piece of cardboard in front of your radiator and stop the airflow that cools your engine coolant. THIS WILL CAUSE YOUR CAR TO HEAT UP AND CAN CAUSE ENGINE DAMAGE IF IT OVERHEATS. Don't completely cover the radiator but if your heater warms up when you put the cardboard in front of radiator it's a good sign that your thermostat is stuck open and needs to be replaced.
Dec 04, 2009 | 1989 Lincoln Town Car
I live in a very hot climate, Yuma AZ. In the
It may be getting low on freon sometimes they leak out
Sep 10, 2009 | 2005 Dodge Durango
What oil does a 96 Chevy Cavalier need?
you can use 10w 30.if you live in a warm or hot climate.if you live in a colder climate.you use 5w -30 oil.
Jun 19, 2009 | 1996 Chevrolet Cavalier
Looking for ac dc adapter for my Sanyo flat panel tv
It periodically goes dead and needs a firm slap in the palm of my hand to get it to come to life again. Unit runs fairly warm so wonder if it is a safety problem.
Dec 17, 2007 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Jun 11, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Heating & Cooling Logo
294 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
