Asus P5QL PRO motherboard with Realtek hd audio soundcard, i uninstalled and re-installed the drives but i still cant get my microphone to work, all people hear is a fuzz, and i try windows sound recorder and nothing
  • 2 more comments
  • graeme ian hunter Jan 03, 2011
    Have you set the volume for the mike in the sound properties and have you plugged the mike into the front or rear computer ports?
  • jamie_j2o Jan 03, 2011
    yea ive got the mic to 100 and even turned some boost up( played around at diff levels)
    the headset and mic are plugged into the rear jacks as i dont think the fronts are working
    What version of windows you using?
    vista 64 bit
    Sergeant:
  • 223 Answers
Hi jamie, i am happy to assist, just view this articl its will help you more to solve your Mic problem , click here to view, And just try to get someother Mic and test your system , because there is a chance your mic may be get fault.
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 03, 2011
There is no sound coming out of my motherboard audio plugs. I cannot find a Realtek audio driver for Windows 7.
You can either go on the Asus support site and download them there with your motherboard model number.
Or
On the Realtek site directly here is the link : Realtek high definition driver download
Good luck
Dec 15, 2010 | ASUS P5QL PRO Motherboard
What is the compatible sound driver for this motherboard my operating system is XP
Normal 0
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Oct 05, 2010 | ASUS P5QL PRO Motherboard
Install realtek hd audio driver failure error code oxe0000227
1) open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio"
2)uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.)
3) install realtek driver the realtek driver includes the UAA driver too.
Jun 07, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
Asus M2V Audio problem
in the bios because you set HD audio to audio it may be that you need to download the HD Audio driver from microsoft
Apr 14, 2009 | ASUS SiS Chipset TUSI-M Motherboard
No audio
You may not have downloads the correct driver software. The Asus P5VD2-VM SE uses the, Realtek Audio Driver V5.10.0.5490 for Windows & HD driver, Realtek High Definition Audio System Software V5.10.0.5366 for Windows. You can download both from Asus by clicking on this link;
http://support.asus.com/download/download.aspx?modelname=P5VD2-VM%20SE&SLanguage=en-us
Please read all of page 1-34 in your P5VD2-VM SE manual to help you setup your audio. You'll need to make a bios change per instruction. If the current software does not uninstall. Enter the bios & disable the setting for HD as shown on page 2-24. Save & exit the bios. The system will auto restart. Try again to uninstall the software, it should uninstall. Create a folder on your desktop & name it HD audio. Download the HD audio software into the HD folder. Do the same for the standard Realtek AC'97 software by creating another folder within the HD folder & naming it, Realtek AC'97. Store V5.10.0.5490 into the Realtek AC'97 software there.
Both files will need to be uncompressed. Enter your bios again & Enable either the [AC'97] or the [HD] setting. Save & exit the bios. Go back into windows device manager. Open the + sign to the left of Sound, audio and game controller. (It will open if it's not already opened).
Rather trying to reinstall by using the sound software's setup.exe file we will do a more direct method of installation.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find you’re desktop folder named HD & open it. Left click once on the folder named (Depending which you are going to install), Realtek or HD, so it is high-lighted. Than click OK.
Windows will find the correct driver software & install it automatically. Once completed. Close all opened windows & restart you’re system. Test your audio. If you intend to use a mic, you will need to set this up through the Sounds audio devices within the control panel.
If you run into any issue just post your question here.
Good luck nxyz215!
Mike
Sep 11, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Ati radeon audio problem
make sure every thing is up to date and you may need some software but i cant tell you were
Jun 23, 2008 | ASUS P5GD1-VM Motherboard
Asus pp5gcx motherboard-realtek hd audio driver" failed to install"from cd.
go to the support site for your motherboard, there you will get universal bus architecture device drive. Install this before you install the Audio/Sound driver.
Apr 14, 2008 | ASUS P5P800-MX Motherboard
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
