Question about GE Spacemaker JVM1640SJ Microwave Oven
The fuse was blown, I replaced the fuse and the display came back. I tried to heat something to see if it was fixed and it dimmed the whole house before blowing the fuse again. Is it TOAST?
  • 1,772 Answers
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if your unit has power, and things lite. it is more likely you have a control/switch problem, you did not give a model number, so i cant tell you if a service call will be worth it.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Jan 02, 2011
My microwave runs and sonds normal but doesnt heat anyhing
First: Check the high voltage fuse (this fuse connects between the
high voltage capacitor to one pin of the magnetron( careful this capacitor must be discharged)), replace fuse if it blown.
Second: If this fuse blown again, the magnetron must be replaced
(shorted).
Note: These answers only apply when the microwave are working with normal sound but NO heat, If strange sound occurred that means could be something else faulty!
Good luck
Sep 08, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Microwave not heating.
1 thing here you can check yourself. You need to remove the cover of the microwave. Make sure it is unplugged first. To remove the cover there should be a series of phillips head screws on the backside of the microwave. Once the screws are removed then you need to lift the back of the case towards the front there is a lip at the front that holds the front down that is why you need to lift the case from the back. Once you have accessed the inside follow the powercord from the plug into the microwave along this cord you will see a fuse. Very IMPORTANT do not touch both sides of the fuse holder at the same time. There is a charge stored in the microwave that will curl you hair remove this fuse with a fuse puller (purchased at an auto parts house) Take the fuse to an appliance parts house for replacement. Should be in the area of 10.00 or so. Replace the fuse put the casing back together and try the microwave. If it doesn't work then the magneto or magnatron whichever the machine has is blown and in that case it is cheaper to buy a new microwave
Good luck hope this helped you some
Dave
Jan 18, 2010 | GE JVM1540DM Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Do not heats up , every think works but do not get hot, I notice that on the power level display something funny like -1-20, what this means and how can i fix it
Fuses
Door switch
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Jun 30, 2009 | Magic Chef Microwave Ovens
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Everything works on the microwave but wont heat food.
You need to remove the cover, (Power Unplugged!!) look for and check a long glass fuse (usually in a plastic housing)
It's 5000 volt and less then one amp rating.
It's a small wire inside fuse so check it with a meter.
If it's ok, it's most likely the Magnetron which is usually half the price of the machine.
If the fuse has blown, see if there is a black diode, 30-40 mm long, one end is screwed to the case.
Disconnect one end, If you have continuity both directions, it's failed causing the fuse to blow.
Replace that diode / high voltage rectifier and then the fuse.
You should be back in business.
jb
Mar 16, 2009 | Maytag MMV5156AAS Microwave Oven
No heat, does not cook
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No light, internal fan...then no display
The light isn't a safety issue but I would think that the fan would be.
The fan is designed to remove excess heat from unit and keep it cool. Without the fan, you're now operating the unit under conditions that it wasn't designed for.
With the unit unplugged, try removing the cover and see if a fuse has blown. If so, replace it with the EXACT value of the original.
See if the unit powers up again. Try heating heating up something for 30 seconds to see if the Magnetron is still functioning.
If so, check to see if the bulb is good. Did the bulb and fan stop at the same time? If so, it might be something in common that controls both.
Don't operate it further until you have it looked at. You don't want to cause something else to fail.
- Jim
Jan 31, 2008 | Maytag MMV4205 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
113 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
