When I go to start my machine, pressing the start button, nothing happens. If I let go of the button and try again, it beeps 3 times and still nothing happens. I've found that if I wait a while (unknown amount of time) and go back, it will work just fine.
  • juliesteiner Jan 03, 2011
    Sorry, I thought this was a site just for Whirlpool Duets. The machine is Whirlpool Duet Model # ghw9400pwo.
    Also, this morning when I tried it again, I got a display code of: Fdl
    Whirlpool Duet GHW9400PWO
    This morning got an error message of Fdl
    Thank you
  • Washing Mach... Master
  • 8,220 Answers
The CCU must be on it's way out.Tech sheet notes: FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/proceedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
When I go to start - themobilian_664.jpgService manual and more HERE
Posted on Jan 03, 2011
    Top Expert:
  • 9,472 Answers
What is the make and model number of your machine?
  • Richard Roth
    Richard Roth Jan 03, 2011
    F/DL
    Door Lock Error
    A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
    before displaying the error.
    Potential Causes
    • Door Lock Mechanism broken or removed from the Door
    • Check Door Lock/Switch Assembly
    • Check the wire harness connections to the Door Lock/Switch Assembly and
    • Door Lock/Switch Assembly Failure
  • Richard Roth
    Here is a link to the part in case you need it.
How do I reset my washing machine?
Sounds like a control problem. Try googling your make and model of appliance followed by "service manual". Most newer, digital controlled appliances have a "secret" service menu where you can check for error codes, stuck buttons, bad sensors and such. Download the tech manual and start troubleshooting. Or you can call an appliance repair tech to come out and do the same thing for a fee.
Jan 02, 2015 | Washing Machines
3 beeps on any button press, machine will not start, and will not go into service mode
Try unplugging and plugging it back in, carefully. The control panel most likely has gone out. These panels are generally readily accessible, so it is not a big deal to replace a circuit board or component. Be sure to unpower the machine if someone is to try this that is not a licensed technician. If you have a warranty it may be time to call someone out.
Aug 31, 2017 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
3 lights keep blinking on umilk nespresso
This means it has entered descaling mode. Press the three buttons on top all at the same time until you hear a beep/chime. Then your machine should be ready to go again. This happened to me once when I didn't notice that the water reservoir was empty and I tried to make espresso. If this happens and nothing else is an issue like what happened to me and the drip tray is empty and in correctly you likely need to descale the machine. You should do so at your earliest convenience so that you don't harm the pump because the machine is full of limescale.
Oct 18, 2013 | Coffee Makers & Espresso Machines
My Macbook Air made "beep
The bios on the machine hardware has failed to book.
You could try plugging in machine and ensure battery is charged.
Press and hold the power button for about 20 seconds.
also the other thing is to immediately after you press the power button.
hold these 4 keys at same time continuously - cmd, alt, P, R
hopefully machine will power up and down and up again if you keep holding them.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Apple MacBook Air
I wnt away from home for a few weeks and when i came back i wanted to play my ps3 but when i turned it on all i got was a black screen so i tried reseting my ps3 sevral times and and still nothing happened...
Have you tried resetting the video ouput?
Try these steps :
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later.
Step 3. Release the power button when you hear the second beep.
Step 4. Wait to see if your PS3 starts up
What this does is reset the video resolution back to standard definition.
Hope this helps and thank you for using FixYa.
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
