! - Do not try to start it.. With all that gas, could literally blow up.
Sounds like the fuel system is not controlling the gas flow. If Carburator, float valve is stuck open. If it's fuel injected, then the diaphram in the flow control maybe rotted out or otherwise malfuctioning, in both cases, allowing the gas to drain down into the manifold, running into the cylinders, and seep into the oil sump past the pistion rings.
Drain and replace the oil, after looking carefully at the fuel supply system.
Oh sorry i thought its a big engine,check your float pin its faulty thx
