Question about Echo Gas Blower 162 MPH 450 CFM Blower PB500H
What fuel does my Echo pb500H use??? 2 stroke oil gas mixture????
    Scholar:
  • 74 Answers
2 stroke means that it is a gas mixture. 4 stroke means that there is no gas oil mixture.
Fuel is VERY flammable. Use extreme care when mixing, storing or handling, or serious personal injury may result.
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Do not forget to rate the answer, Thank-you
Posted on Jan 03, 2011
  • 784 Answers
The oil/fuel mix ratio that we use in our Echo blower is a mix of 50:1 and it runs very well.
c...
Posted on Jan 02, 2011
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
What fuel does stihl MS 192 T take, 2 or 4 stroke?
these small engines take 2 stroke oil/gas mixture, usually a 50 : 1 ratio, a little heaver on the oil is better than too light. the oil in the gas lubes the internal parts of the engine. if straight gas is introduced into gas tank just remove & replace with 2 stroke mixture. if engine has not been operated with straight gas, no harm will be done.
Apr 26, 2014 | Garden
Runs like choke is stuck on
You need to make sure your oil to gas ratio is being mixed correctly - dump out the gas and dispose of the fuel IAW state laws - mix fresh oil and gas fill - fire up the unit and let it run for 10 -15 minutes to get all the bad fuel out - replace or at least clean the plug and air cleaner
Jan 09, 2013 | Echo Gas Blower 162 MPH 450 CFM Blower...
What is the fuel/oil mixture for my echo pb 250 blower
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
Jul 22, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have an older echo blower. just had it tuned up and adjusted and still running poorly. just wondering if it is my fuel mixture of 25;1
25:1 may be too rich a mixture. Clean your spark plug well. Then get some good synthetic 2 stroke oil and try a 32:1 mix or a 40:1 mixture. Here is a fuel mix chart for you use.
May 15, 2011 | ECHO, Inc. PB-251C Handheld Blower
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Whats correct gas mixture for 2400 echo edger
Your owners manual states: 50:1 Echo High performance 2-Stroke Air Cooled Engine Oil
That would be 2.56 ounces of oil to 1 US Gallon of gas.
Oct 18, 2010 | Echo Garden
What is correct fuel mixture for Echo CS 6701 Chain saw?
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 08, 2010 | Echo CS600P Gas Chainsaw 20 Inch
I have an Echo 300E leaf blower and can't find the gas oil mixture.
Here it is straight from ECHO:
Link is http://www.echo-usa.com/faqs.asp
Apr 19, 2009 | Garden
Echo Gas Blower 162 MPH 450 CFM Blower PB500H Logo
1,950 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
