Question about Sony HVLF58AM Digital Camera Flash TTL for Alpha Series HVLF58AM Flash
I have been having trouble with my Sony Flash HVL-F58AM. The flash fires but the picture with be dark, or completely overexposed. I have tried the flash with every camera I have: the A900 (both of them) the A700 and my A 100. The same thing happens with every one. Please help!
  • Edgard Diaz
    Edgard Diaz Dec 24, 2011
    I have the same problem! I have an alpha 900 + a F58AM flash, and when I take pictures, regardless of the mode (Aperture, Shutter, Auto) pictures come out very dark. Flash settings are automatic, but anyhow with manual settings to full power it wont come out right. Too dark. Also I try to step up EV even by 3-4 stops to try, but no result. Have you had any luck?
Arpi
  • 326 Answers
SOURCE: Auto Settings Mode
Hello jmmarsh, replacement of the flash unit is the righ solution. 50 Euro for my account. If you need more info, please advice. Arpi
Posted on Mar 17, 2007
SOURCE: Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Posted on May 18, 2007
SOURCE: sony cyber-shot flash issue...
Service required
Posted on Nov 24, 2007
SOURCE: E:91:01 flashing
i also have E:91:01 flashing on my camera and when i take a picture it does not flash even when my camera is on flash
Posted on Oct 21, 2008
SOURCE: Quantaray PZ-1 DSZ and Sony alpha 100
Having the same problem with the Quantaray 7500A and my Sony Alpha 200. I either have to go to full manual or overexposed. I've sent off a few emails to Ritz but still haven't gotten a reply.
Posted on Nov 02, 2008
Is it that flash working with sony alpha 380? or this is only cammcorder flash
From the manual: "The HVL-FH1100 flash is for use only with video cameras equipped with the Intelligent Accessory Shoe." The alpha380 does not have such a shoe.
Feb 11, 2013 | Sony HVL-FH1100 Flash
Is it possible to use Sony Flash HVL-FH1100 with fotocamera Sony A55? Is there any adaptor or other way?
Sorry, no. Sony intends the HVL-FH1100 for use only with their video cameras and they consider the A55 to be a still, not a video, camera. Yes, the A55 has limited video capabilities, but it's not really a video camera.
Jun 04, 2012 | Sony HVL-FH1100 Flash
How do i use the flash on the Sony Cyber-Shot
on many sony models such as the dsc f707 and f717 and probably on your model as well ... sony uses a special flash that actually flashes twice .. it does it so fast that it looks like one flash .. the first flash sets up the metering.. the second takes the picture .. so if you try to use a standard flash you will get a dark image since they only flash once .. so you have to use a special flash attachment that is capable of double flashing .. sony, of course, makes them (HVL-F1000) and some outside suppliers as well .. sony calls it "intelligent flash"
here is a low cost "auto slave" flash for your camera:
http://www.amazon.com/Cybershot-DSC-F505V-Complimentary-Super-Deal/dp/B002LCTXG2
you dont have to hook this one up .. it uses the normal camera flash to trigger itself .. so you can move it around to get lighting effects or mount it on the camera to augment the normal flash
if you just want to use the internal flash (good to 8 feet) then here is some info ....
http://www.steves-digicams.com/f505v_pg2.html
Jan 19, 2010 | Sony Cyber-Shot DSC-F505V Digital Camera
Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Sony DSC W50 Camera - Trouble with Flash
Hi, I guess you are using the automatic mode ( not the "P" mode).
You should enable flash only when there is insuffient light. If you use flash in broad day light, your pic will be whited out. If you dont use flash in dark or low light, your pic will be dark or very dark.
So, when it comes of dark, try enabling the flash. If its still dark, increase the flash compensation (the eV value). If its still dark, increase the ISO number.
Hope these help.
cheers,
Sep 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Jul 30, 2008 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Dark or Bright images
It might be that (sometimes) the battery is not strong enough to quickly charge the flash and you take a picture when it is not yet able to flash at the power level it needs to. This may be that the battery is weak and/or you try to take a second picture too quickly after the last flash.
On other occasions (when the images are blown out, I.E., overexposed) you are probably too close to your subject and are not using a reduced power flash setting. Experiment with a well-charged battery. Without reducing the flash output you will allways get this overexposure if you are a few feet away from the subject
Dec 31, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Synchronization problem
Set camera to Manual modes
Set Shutter to 60
Set Aperture to 5.6
Set ISO 400
Set lens at 10 feet
Subject at 10 feet
Turn on flash and wait until fully ready and do the following:
Set subject dead center, shoot with flash
Set subject to the right, " " "
Set subject to the left, " " "
Only the subject in center should have correct exposure.
Hope they are helpful.
Alexander
atdlee@netzero.com
Dec 14, 2007 | Sony HVL-F36AM TTL Flash
Time for new flash??
the camera's light sensor or metering system, for correct flash exposure is no longer working, that's why your shots is either black or white (overexposed or underexposed) the flash firing has loose its control because of the defective sensor, it now only depends on the charge current of the flash capacitor. If you'll wait longer time the charge is maximum picture result will be overexposed(white), and vice versa, less charge, dark result, have the flash assy replaced. Daylight no problem, it doesnt use the flash circuitry, thanks
Jul 28, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Auto Settings Mode
Mar 05, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony HVLF58AM Digital Camera Flash TTL for  Alpha Series HVLF58AM Flash Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
