Question about Dimplex Heating & Cooling
Power at the wall thermostat, power at the heater, but doesn't heat.could it be the thermostat on the wall?
    Novelist:
    Champion:
  • 224 Answers
It could be, here is what I do to verify that the problem is in the thermostat. Remove the thermostat from it's mounting plate, you should now be able to see the wiring for the thermostat. Locate the red and white wires, they usually run the control for the heat, now place a jumper to join the red and white wires. The heater will now run with out a thermostat, if it runs yes it is the thermostat, if not you need to look in to the control side of things. This means either good electrical trouble shooting skills or time for the repair man.Good luck
Posted on Jan 03, 2011
  • Anonymous Jan 11, 2011
    thanks for the advice. but found the problem.broken wire at the base of the heater. clamp must have been to tight and sheared it off.
  • jmonoski Jan 11, 2011
    That is wonderful so glad you found the culprit, check all of your connections what happens is some people try the old trusty wire cutters and utility knife for stripping wires. Using these instead of T-Strippers can score the wire and once it heats the wire breaks at the score. So if you found one you are liable to find more. Happy heating!!
Cozy wall heater. pilot stays on heater will go on once in a while by moving thermostat up. will run for about a minute then won't react to thermostat when i try to get it going again.
Shut the power off. Pull the thermostat off the wall and jumper the two wires, meaning put them together. Turn the power back on and if the heater works fine its in the thermostat
Dec 06, 2017 | Cozy Heating & Cooling
Changed thermocouple and thermostat on wall heater but heater will not turn on.
Thermocouple senses the pilot light, the gas valve is controlled by the thermostat and that is powered by a transformer. Check for voltage from the power supply transformer to the thermostat. Check the gas valve for continuity.
Jan 19, 2017 | Heating & Cooling
Room Thermostat--Right near heater
First move that fridge!! Constricting the airflow like that not only makes the heater cycle too much... it's a safety hazard.
Once you allow the heat to circulate properly you can address the issue further.
Oct 26, 2013 | Heating & Cooling
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
One of the thermastat wires attaching to the williams heating on the wall became loose from the screw and didn't seem to be making little of no solid contact like a car battery might due. i tightened the...
If it touched a grounded metal surface, it is possible, leave the wires hooked up at the furnace, pull the thermostat off of the wall, disconnect the 2 thermostat wires, and then twist them together, the furnace should fire, if it does, then the thermostat is shot. Replace the thermostat, usually when there is a short, it burns out the heat anticipator on the thermostat.
Good Luck,
Paul Gibson
Apr 03, 2010 | Williams 1403622 Gas Compact Heater
I recently installed a new elec. baseboard heater with a wall thermostat in a new addition. i wired a 220 tstat. there were 2 red line wires on the tstat. there were 2 black load wires on the tstat. i put...
When you checked across the black and white at the heater did you get 220v? If you do, then the heater is bad or the high limit is kicked out, check it out to see if it is open (no current will flow through it).
Nov 13, 2009 | Heating & Cooling
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Frequent cycle times on my home furnace
There are a few things that can cause this problem. The most common is the hole behind the thermostat for the wiring was not covered up when the thermostat was installed. The thermostat will sense the air in the wall space or the basement if it is open to the back of the wall supporting the thermostat. Turn off the power to the air conditioner if attached and the furnace, remove the thermostat from the wall and seal up the wiring hole with duct tape. Insure the thermostat is mounted level when reinstalled. The thermostat should be mounted to sense the return air to the furnace, if the stair well leads upstairs, warm air rises, so keep the upstairs close to the same temperature as down stairs or move the thermostat and install a door to block air movement to the upstairs. There is a heat anticipator on the thermostat, the setting for it is in the installation manuel. For most gas furnaces it is .8. It is very easy to short out the thermostat when making this adjustment, so always have the power off.
Nov 26, 2008 | Honeywell Electronic Programmable...
Wall gas furnace
look inside the control panel of the heater. look for a 120 volt to 24 volt transformer.  There may be a fuse on the transformer secondary.  The thermostat switches a hot 24 volt wire so you won't find a common at the thermostat.
Nov 13, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Heating & Cooling Logo
148 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
