Question about Whirlpool WTW5300SQ Top Load Washer
I have a Whirlpool WTW 5300 VW2 washing machine. When it fills warm or hot water, the water pulses. We replaced the solenoid valve and it remains the same. The sound is annoying. Any ideas?
SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
SOURCE: Whirlpool not agitating
Hi everyone - I ended up calling a repairman. It was small part that needed to be replaced. It cost me $65 for the visit, $20 for labor and $20 for parts. The repairman told me it would probably be good for another 5 years.
Posted on Nov 13, 2007
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
  • 378 Answers
SOURCE: my whirlpool front load washing machine accept hot
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Posted on Apr 03, 2009
honeymokey
  • 3113 Answers
SOURCE: Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Posted on Apr 08, 2009
Whirlpool WTW5300VW2 washer hot water pipes shake during fill
Good day,
The only test on the water valve itself, is to replace it. The term is
"replace with a know good part", but may or may not work.
It is very possible you mght need a plumber to install a riser on the hot water line somewhere betwen the tank and the line going into the washer. The riser creates an air cushion in the line that is used on many issues much as you described.
It could well be best to call a few quality plumbing companies, to see if they have dealt with that issue.
Jul 13, 2010 | Whirlpool WTW5300SQ Top Load Washer
F&P GW611 with a cold water trickling in. Looked like a weak solenoid so replaced with a new one part 420148P and no real difference. To get by swapped hot with cold solenoids. Now finding hot water is...
Check 1st if water is flowing well from the hose. hold it over the sink or bucket/if not could be faulty water valve..Put valves back to original as hot may have a reducer to cut down pressure hence the pulsing that you say...
Feb 08, 2010 | Washing Machines
During the water fill cycle there is not a steady flow of water entering the machine when on a HOT or Warm cycle.The water is Pulsating through the hoses.Is this normal for a wtw 5600 whirlpool washer???...
Hi Charlie in Philly,
Yes it is normal to answer your question in short. However, since it may not be how your old machine operated or something you are not accustomed to, I'll explain in brief.
Most automatic washer made today have a "thermistor" built into the fill valve, or in series with the fill line from the valve. As a result you may notice either the cold or hot pulsing on and off, and this is done as the thermistor senses the water temperature to attain the desired water for the selected cycle. It also makes the washer more energy efficient and more well balanced from a functional stand point, i.e. it will only call for the desired amount of hot water as opposed to the older washer's which would simply fill at the rate at which the home water supply could provide, whether hot/warm or cold selected.
Hope this answer's your question and enlighten's you to the "why" as well.
Thank you for visiting "fixya" today. If you found this solution helpful please take a second and rate it or comment on the expert reply.
Let me know if I can assist you further and good luck with your new washer.
macmarkus :)
Jan 21, 2010 | Frigidaire GLET1031 Top Load Stacked...
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Warm water question
there seems to be something malfunctioning within the water inlet valve assembly. check the wires leading from the control board to the water valve assembly. make sure the connections are tight and fitting well. also, do a break point test on the control board. this will tell you if the control board is sending crossed signals to the water valves.
Mar 13, 2009 | Washing Machines
Whirlpool Clothes Washer Model LSR7233DWO Cold Water Fill
It is a common problem. The water inlet valve (the item your fill hoses attach to) has a problem. first thing I would do is remove the hoses and check the screens inside the walve itself. If blocked, clean them. IF they are OKAY....WHile the hose if off place it in the washer tub and turn it on full blast. Does it flow with force? If so, you will need to replace the water inlet valve. While on cold....it trickles and turning it to warm, the machine sends power to both the hot and cold water solenoids and then you are forceful. Mostly hot and a trickle of cold.....Get the point? If I can help further...
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Whirlpool Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Whirlpool WTW5300SQ Top Load Washer Logo
147 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
