Question about RCA RP5022 Digital Voice Recorder
Sometimes I record something and then when i listen later there is something else that comes up on that particular recording. In this case it was something I erased a long time ago. Why does that happen and how can I retrieve the stuff I actually recorded at that particular time?
  • 2,069 Answers
Iin this case, You can solve this problem by running "Error Checking" on your computer. You Go To: "My Computer" and find your RP5022 Drive Listed there. "Right Click" on it and Go To "Properties"...Once Open Click On "Tools" and Look for the Window that says "Error Checking". Click On "Check Now" when it Opens (Be Sure) to (Check the 2 Boxes) Listed. Let it run the Error Check...AND RESTART YOUR COMPUTER WHEN FINISHED.hope this helps.
Posted on Jan 04, 2011
How do I record myself singing
Much depends on the sort of quality you need and the duration of the performance.
Smartphones, tablets, digital memo recorders and suchlike are capable of recording but due to the size the quality isn't great and in some cases the duration they are capable of would be limited.
Whatever system you choose will provide a problem because recording the choir will be relatively easy but recording you singing with the choir will be more difficult. A microphone would need to be carefully placed on a stand close to you perhaps or you would need to hold it or you could stand apart from the choir.
The logistics will be for you to sort out with the choirmaster and the other members...
The device is another matter. The simplest would be a quality cassette type tape recorder. These have been obsolete for years but there is still quite a few around. Even better would be an old reel-to-reel tape recorder but those are now few and far between. The advantage of these are they just need loading with tape and switching on...
Some video cameras have amazing stereo sound and in particular the VHS video camera/recorder. Other cameras have sound capability and sometimes it is very good so they are another option....
Perhaps the best option for these modern times would be a half-decent laptop computer loaded with recording software. There are many programmes available and some are free and some will turn the laptop into a virtual recording studio. Goldwave is free, and very stable and reliable but it can be tricky to make it work. Add a compatible microphone and you are all set. The better the quality of microphone the better the results will be.
Happy singing!
Apr 02, 2017 | Audio Players & Recorders
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
Ok so i wanted to record something then there was something that said would u like to active recording automatic then i press it ... i want to cancel it but i can what can i do??
Hi pililis_75 my name is Mike Houston of DISH Network and Isee you wanted to record something and you had a message come up. If you see aprogram you like and start to record it and decide later while it's recordingyou want to stop it you should see a digit message come up on the top right of thescreen. The Message you should have seen would have been #312, it will ask youif you want to stop the recording to select Yes or Ok. If it will not let youstop the recording press and release the SAT button and then try to stop it. Ifyou have any other questions or concerns please let me know at michael.houston@dishnetwork.com.
Aug 27, 2011 | DISH Network DVR-625 DTV Receiver /...
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
I recorded minutes and was able to retrieve the first 30 minutes of the recording. Two days later I went to finish them off, but the microcassette appears to be blank. No sounds, nothing. How is this...
Hello try to used and external headset to make sure the speaker is not the problem, if no audio come out the headset when you are listening watch the red light indicator and talk if the red light blinks you unit may have the internal record switch broken and you may over recording your tapes you can send your unit to repair but I think is cheaper to get a new one, you can get a similar one at http://www.tvps.com/Products/SONY-M-675V-Micro-Cassette-Recorder---New-M675V__SO-M-675V.aspx
Mar 10, 2011 | Sony Pressman M-560V Handheld Cassette...
I have a Samsung T406 cell phone. How do I record a new greeting message?
That usually has to do with the cell phone provider's voice mail, not the cell phone.
Call your voice mail. Instead of listening to messages listen to all the menus.
You'll want something like "setup" "record new outgoing message" or things like that. Usually you can listen and choose to save or do a new recording. You might need to press star (*) or pound (#) buttons to save or cancel the recordings - or maybe numbers 1 or 2.
Feb 11, 2011 | Cell Phones
I have problem with my camera in when im recording video there is no sound any one now something please help me
Many still cameras that have the ability to record video clips have no sound. There just isn't a microphone. I don't know this particular camera intimately, but what you describe is quite normal for cameras of this sort, and not a fault. If you want sound on the clips, you can dub it on later by editing the clips on a computer.
Nov 04, 2010 | Sony Cyber-Shot DSC-F55 Digital Camera
How to record conversation with a caller
when the call is active, select option> you will get the option for recording the call conversation. And the call will be saved under voice record folder
Jul 19, 2010 | Samsung B5722 Cell Phone
I was listening to a play back of a song i was recording when everything stop and window indecated that DRIVE BUSY Don't know what to do?
if it came back after a while then thats the way it is with digital recording sometimes. if it didnt come back that indicates something more serious.
Dec 20, 2009 | Boss Micro BR Digital Recorder
Recording Mixes from IDJ2 to my MAC
I don't know about MACs but I assume most computers are the same in their general anatomy when it comes to the sound system.
ie. Windows has a digital recording system built into the OS that allows you to plug an 1/8" patch cable into the "input" of the soundcard of the computer. Years ago I recorded several things from karaoke songs I sang to pre-recorded song I mixed from my DJ console. The volumes needed to tweeked to avoid sound distortion but it sounded so good I've used my recordings at gigs.
Feb 01, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
RCA RP5022 Digital Voice Recorder Logo
64 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
