My washing machine is not working properly when moving the washing machine out of my apartment I noticed that one of the pulleys was ruined and the washing machine was smoking very badly it is the pulley on the right hand side of the washer on the bottom and also the belt is ruined. How hard would it be to replace and also how do I get a hold of Magic Chef to see if the washer is still under warranty.
    Novelist:
  • 177 Answers
Go to repairclinic.com or partselect.com to get the parts, you will need a model number.
Honestly I dont know if Magic Chef even builds washer anymore or has in the past several years. with that I would assume your warranty has expired. You will need copies of when you bought the washer and a copy of the warranty to full fill any warranty claims plus an authorized Magic Chef service agent will have to preform warranty work if it is still under warranty.
Posted on Jul 09, 2008
How do I remove tights stuck underneath agitator on a GE GTWP1800DWW washing machine?
Do a google search for manuals. Or go to YouTube.com or appliancepartspros.com or repair clinic.com for repair videos. Put in ur make/model and search agitator. Good luck and good for u for doing the right thing.
Mar 26, 2015 | GE Refrigerators
Why did my tines stopped working
Hello, Did you notice if the tines moved when you turned the belt pulley to install the new belt? If the tines do not move when you rotate the driven pulley by hand, the worm gear might be stripped. If the tines do move when you rotate the driven pulley by hand, the belt tensioner might not be working properly. It could be as simple as an adjustment.
Aug 28, 2014 | Garden
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
Washing machine banging noise
It could be the main shaft on the drum or misalignment. There is some flexibility, but not a lot. Check for worn belts, pulley wheels, and other attachments.
Feb 26, 2014 | AEG Washing Machines
I have a Whirlpool Duet Washing Machine (GHW9100LW1). The washer stopped spinning, but the motor was going. I took off the back and noticed that the belt had come off and there was a lot of black...
The first thing to determine is if the pulley is loose due to wear on the pulley or if the spin bearing in the outer tub is bad.
Remove the belt. Make sure the nut holding the pulley in place is tight.
Wiggle the pulley while shining a bright lamp on it.. is it loose on the shaft or is the shaft moving.
If the shaft is moving.. outer tub needs to be replaced.. and in some cases this means the spin basket as well.
If you remove the pulley..and the inside mating surfaces which are flat on two sides are worn or rounded off.. bad pulley.. the retaining nut may not have been tightened properly.. or it became loose up over time,
However the black dust means the belt has been slipping ..some dust is probably normal due to age.. rubber breaks down..but a lot of dust means friction.. which means something is not turning as freely as it should.
So it has to be a loose retaining nut, worn pulley..or worn failing outer tub bearing.. I am afraid it's more than likely the last one.
Sears Parts Direct will have diagrams for your model..
Best of luck
May 12, 2011 | Washing Machines
Admiral Capacity plus, 2 speed, model# LNC6760B71 stopped in mid cycle, found motor pulley burned right off, belt on floor. How do you find out what caused this ?
possible the belt had stretched and the pulley was turning but the belt wasnt moving causing it to get hot and break
make sure the electric motor is turning and also the pulley that turns the wash tub, fit the new belt and make sure you tension the belt or it will slip again and ruin the new belt
Jun 13, 2010 | Washing Machines
Maytag EpicZ Washing machine; basket drive pulley noise & wobbly
sounds like a bad bearing...here is how I check them open the door .lift up on the tub if any play in the upwared monment it's bad...you can also remove belt and pulley spin the tub if you still hear the noise it's bad....
if bad you will have to replace rear outer tub and spinner (it has the shaft on it)
also Give Maytag a call at customer relatiions...make a lot of noise they may just give you the repair..
Sep 21, 2009 | Maytag EPICz 3.7 cu. ft. Washer
Belt
We'll assume no problems with the belt installation - the tensioned idler pulley is pressing against the belt etc.
You didn't say whether it drained out OK or specify what model but it sounds like the brake is stuck or there's something caught in the basket. Try turning the main drive pulley (the one in the middle) Even with it full of water it should turn freely. Take the tub top off and check for foriegn obects stuck between the basket and outer tub. A wire coat hanger works well fro this.
Jan 04, 2008 | Speed Queen AWS75NW Top Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
