Question about Microwave Ovens
Operating Manual For Cooks Nonstick Electric Griddle, FC780-2175
COOKWORKS MICROWAVE TIMER
Replacing the timer could solve the problem
Sep 25, 2012 | Microwave Ovens
I need a manual for the cooks essential pressur cooker # 99700
IF YOU HAVE INTERNET ACCESS, TYPE IN THE NAME OF YOUR MICROWAVE AND MANUAL AND DO A WEB SEARCH! COOKS ESSENTIAL PRESSURE COOKER MANUAL FOR MODEL NUMBER 99700
YOU'LL FIND MORE INFORMATION THAN YOU'LL PROBALLY NEED, BUT YOU WILL BE ABLE TO DOWNLOAD THE MANUAL AND SAVE IT OR ATLEAST FIND OUT HOW TO CONTACT THE MANUFACTURER TO HAVE THEM MAIL YOU A MANUAL!
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Microwave Ovens
I need an LPH-2 thermostat power cord for electric griddle
Thank you for posting on FixYa. I might be able to help if I knew your make and model number.
Jun 03, 2011 | Microwave Ovens
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
I bought the waffle iron at a church thrift shop and there wasn't a manual or recipes
Hello Anyduckfood,
I understand that you purchased a Waffle Iron at a church thrift shop you did not receive the directions or any type of recipes for the unit.
Most waffle irons are set up to cook a waffle in one minute. They take a few minutes to heat up like about 5 and then you may cook with them. You generally use a nonstick spray (pan, etc) then put your batter on the lower griddle and close the upper griddle. The batter will expand to the upper griddle and make the shape of your waffle iron.
Recipes: there are many different places that you can find waffle recipes, here are a few links to recipes
http://allrecipes.com/Recipes/Breakfast-and-Brunch/Waffles/Main.aspx
http://www.waffle-recipe.com/
http://www.mrbreakfast.com/recipe_collection.asp?subcategoryid=5
to find more waffle recipes just type "Waffle Recipes" in a search engine of your choice and you will probable by amazed at how many different recipes there are.
Thank you for choosing FixYa.com
Justin
Mar 31, 2011 | Microwave Ovens
I need operator/ instruction manual for a Welbilt Toaster oven/Broiler with rotisserie and griddle. Model # TB6080
WELBILT APPLIANCE CORP.OF AMERICA P.O. BOX 220709 GREAT NECK, NEW YORK 11021 Write to this address and they should send you a manual for your toaster oven, here is a phone # also1-800-872-1656 Hope this gets to you Heather_s514 From smoothygirl63@yahoo.com
Oct 01, 2010 | Welbilt Microwave Ovens
Microwave runs but food does not heat
If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Sep 23, 2009 | General Electric Microwave Oven
Can not find the locking mechanism on g.e. mongram oven
I'm not sure I understand what your problem is here...
The model number is usually found on a tag on the back of the unit, inside the cooking cavity, along the side of the control panel frame, along the edge of the door frame, or on the owner's manual if you have it.
If you still can't find the model number, please tell us what exact problem you're having and / or what you're tryng to do, and we'd be very happy to help you the best we can.
Nov 24, 2007 | Microwave Ovens
Microwave Ovens Logo
147 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
