Question about Brother Disney ULT-2002D
I just had this serviced and I embroidered a few items, I thought that it sounded a little loud. all of a sudden the needle broke. I took the bobbin out and there are scratches on the bobbin shuttle, and the needle is not where it should be hitting .
    Genius:
  • 1,788 Answers
I would take it back and tell them to fix it right. Was it an authorized service center? If, it was there should be no question. As long as you had your needle inserted right, I don't see how it could be your fault.
Posted on Jan 03, 2011
I purchased a singer quantum xl-5000 for small embroidery projects about two weeks ago and trying it out. When I am embroidering the top thread looks good but my bottom has a little loop while the bobbin...
Loosen your tension on your tension adjustment. It will show you where in the manual. Just feel it out a little at a time until it feels better and the problem goes away. Stop before the needle breaks and all but some machine you have to work the kinks out.
Oct 03, 2017 | Sewing Machines
Does not sense when the thread is broken during embroidery. Also does not sense if needle is broken causing damage to item being embroidered. This also does not alow for me to back space to position where...
I have an Artisa 180. WHen the threads break I stop it and backup the stitches to where it broke. Read up on your machine and see if it can do this. Look for the icon on the embroidery machine that looks like an S with a tail! It allows you to move forward or backward in the design and find your place where the thread broke. It can salvage a design so you don't have to start over.
Jan 14, 2011 | Bernina Artista 170
Needle broke while embroidering. I replaced the needle, but now it is jamming and will barely move.
Maybe you have broken threads under the needle plate, Can you lift the needle plate and clean?
Dec 08, 2010 | Brother XL-3500
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Thread get's tangled and attached to plate while embroidering
Just a thought. Is it possible that your thread is wrapping around your spool post or snagging on your thread spool?
sewman7
Jun 09, 2008 | Bernina Artista 180
Viking 1+--Thread breaks during embroidery
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Mar 23, 2008 | Husqvarna Viking 1
Sewing Machines Logo
59 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
