Question about RTO Central Pneumatic Gravity Feed Spray Gun 20 Oz.
Are there smaller tip sizes than the 3 standard that come with this?
What is the standard size of a pinball ball?
the standard size is 1 1/16" there are some machines that use smaller balls you can check online for what size you should use for your particular machine.
Oct 03, 2013 | Video Game Consoles & Games
Tip
Tips on changing orifice size on AC or heatpump
Tips on changing orifice size on air conditioners and heat pumps.
A smaller orifice will create these changes
1 - Takes more refrigerant charge to get the same superheat
2 - Increases capacity
3 - Decreases Energy Efficiency Ratio
4 - Increases Head pressure
5 - Increases sub cooling
6 - Reduces suction pressure
7 - Increases Watts and Amps
A Larger orifice will create these changes
1 - Takes less refrigerant charge to get the same superheat
2 - Decreases Capacity
3 - Increases Energy Efficiency Ratio
4 - Decreases head pressure
5 - Decrease Sub cooling
6 - Increases suction pressure
7 - Reduces Watts and Amps
on Jan 26, 2010 | Heating & Cooling
What is the headphone jack size of the fender sp-10 10 watt amp
Call your local stereo store. These items are very standardized.
There are 2 standard sizes for headphones. the one for PCs and phones is the smaller size. An amp or receiver probably take the next size up. If you screw up and get the wrong size someone like Radio Shack or the like will have an adapter that sells for a buck or 2.
Jul 03, 2012 | Fender Sp-10 Electric Guitar Amp 10 Watt
I have an old gateway 7023ge computer and i wanted to find out the size of my cooling fans so i can replace them. i have 2 fans one front and one rear. they are both the same size.
Computer case fans for older computers were usually standard sizes of 80 millimeter or 92mm, maybe120mm. 25.4mm = 1 inch, so an 80mm fan is about 3 inches. Measure the diameter of the fan from the tip of one fan blade to the tip of the opposite fan blade. A 92mm fan is about 3 1/2 inches in diameter and a 120mm fan is about 4 3/4"
Again, these sizes are _nominal_, so whatever your measurement is closest to is what you need. You should be able to measure the rear fan from the outside back of the computer without taking anything apart.
Jan 29, 2011 | Gateway (8008625) Cooling Fan, Heatsink...
The Tv screen is much smaller during video games than what it is during Movies. Please Tell me how to adjust my screen size.
Movies are shown at a higher resolution than games. That is why the picture is smaller with games than movies. If you turn the Auto Picture Size off, you can set lower grade video to a larger screen size but you will lose quality.
Hope that helps.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have recently moved into a new flat. When I tried to connect my washing machine hose to the tap/faucet I realised that the faucet was smaller. How can I connect my washing machine pipe if the faucet is...
tap will be 1/2 or 5/8 bsp you need to know which and get a 3/4bsp to 1/2 or 5/8 reducer. 3/4bsp is standard size now. Or change the taps to standard size. just realized you may not be uk in which case this may not apply . look in your manual for connection size.
Aug 24, 2010 | Haier HLP21E Top Load Washer
What are the correct tips to use with no gas welding for the MIG130en.
that depends on the wire size you are using,tip size must match wire size.if tip is smaller that the wire size wire will not feed,if to large the wire will bounce around and wont give a good weld.
Dec 08, 2009 | Welding Tools
I need to change the alternator on a 2001 ford focus and need to know what size wrench is needed to loosen the timing belt tensioner enough to remove the timing belt. Please help
I don`t know the size,but it will be metric.If you have a standard,american set of wrenches,get the one that is closest to fitting the bolt head.Here is something to help you decide what the actual metric size wrench to use.8mm is 5/16,,,10 mm is smaller than 3/8.11mm is a 7/16.12mm is larger than 7/16 but smaller than 1/2.13mm is 1/2,14mm is 9/16,15 is bigger than 9/16,but smaller than 5/8.,,5/8 is 16mm.17mm is 11/16,18mm is bigger than11/16,but smaller than3/4,19mm is 3/4.I hope this helps.
Oct 30, 2009 | Ford Focus Cars & Trucks
How many teeth on the standard front and rear ccm 604e 2001
there is no real standard sizing, just keep in mind Smaller sprockets = higher top end speed but lower acceleration and Larger sprocket = low top speed but high acceleration so the size you want is totally dependant on what you require from the bike. eg. if you ride enduro then you probably want something in medium size range so to get decent acceleration but with a good top speed.
Jul 06, 2009 | 2007 CCM FT35s
Copy orientation
Basicly, the check is smaller then a standard LTR size paper. The copier will only see it as a standard size. You will have to put a standard size peice of paper behind that check on the glass so it will read a standard size of paper.... The copier will not know that you are coping a check... They are not that smart..... Good Luck
Nov 11, 2008 | Office Equipment & Supplies
RTO Central Pneumatic Gravity Feed Spray Gun 20 Oz.  Logo
125 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
