Make a jumper wire and jump the two terminals where the thermostat wires into the furnace, generally R and W terminals or TT terminals. If unit fires, you have a thermostat or thermostat wire issue. If it still does not run, check for 24 volts at the gas valve. Could have a bad transformer, bad gas valve or the relay for gas valve is bad.
Sorry to read about your issues.
But you really need to give us the make and model, of your unit. It kinda helps us to help you.
