Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Where is the power cord to my new Gold Dishwasher? Why don't the instructions address this?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
lower right hand corner of unit at the base, turn off circuit breaker before acess
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Does the Whirlpool Gold dishwasher have a fuse?
The fuse is in the control panel on the right hand side after you open the panels 6 screws.
The replacement fuse kit comes with a wire harness that must be used to prevent the new fuse from blowing.
Jan 24, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Replace electric cord
First,follow manufacturers instructions if possible.
If you need a 4-wire cord you will attach the black wire to one of the gold or brass colored screws on the dryer hookup and the red wire to the other brass or gold screw. The white wire will connect to the silver screw and the green wire will connect to the green screw or to a screw that is connected to the frame of the dryer.
If you need a 3 wire cord you will place the two outside wires (if looking at the cord if laying flat), one on each brass or gold screw.Next there should be a metal strip or jumper that you will place to connect the green screw connected to the frame of the dryer and the silver or white screw together. Then place the white, or center wire, on the silver or white screw.
Instructions that came with the dryer should show you how to do this.
Make sure the cord is unplugged before unhooking the hold cord or installing the new one.
If you see something different that what i describe or need anything else just write.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need hoses and electric cord
Water inlet hoses can be had at your local hardware store same with drain hoses, electric cords? If this is a built in unit then you have it hardwired into your homes electrical system. Plug in cords would be a no no.
Feb 21, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
