Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
Chamberlain Power Drive / Whisper Drive My garage door starts to open and immediately reverses but continues to run. I had to release the cord to allow the chain to run its course before it would stop. We can not manually lift the door open even with the cord released One sensor is green and the other is orange. I have tried to realign but can not get the orange light even flicker when moving the sensor.....where do I go from here? Thank you
    Novelist:
  • 128 Answers
It sounds like the door is your problem.
Check the counter balance spring above the door. It is likely broken.
If the door cannot be operated manually, the garage door opener will not open it either. The machine is made to operate a door that works correctly. If the door is broken, the machine will not work either.
It also sounds like the opener gears may be worn out. That also occurs because the door required service.
Posted on Jan 03, 2011
Why is my chamberlain opener showing an orange light and beeping?
That tells you the opener is running on battery power and that the battery is getting low. Check your outlet and make sure you have power going to it. Could be something a simple as a tripped breaker.
Jul 29, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
I have a Model 139.53684 keyless enty need to reprogam code - have a Chamberlain Whisper Drive Operator. Can you give me insturctions
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Mar 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
How do i change the code on my keypad outside the garage door on my chamberlain whisper drive? someone stole the sticker from the pad... thanks
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Door would not close all the way
DOES IT REVERSE OR STOPS BUT NOT TOUCHING THE FLOOR?
IF IT DOESN'T TOUCH THE FLOOR YOU EITHER NEED TO ADJUST THE DOWN TRAVEL OR LENGTHEN THE CONNECTING ARM.
IF IT REVERSES YOU NEED TO DETERMINE IF IT IS THE SENSITIVITY OR THE SAFETY EYES.
Jan 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Installed Chamberlain Whisper Drive but door slides backwards
It sounds like you may have a spring problem. Release the door from the opener and see how it acts manually. Open it as far as the opener does and then see what happens when you release it. Also the weight of the door should give you a clue.
Aug 24, 2009 | Liftmaster, Chamberlain, Sears Door...
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
530 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
Owen Barnes
OtherBrother
Level 1 Expert
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
