Question about Lexmark Wheelwriter 5 Series II Typewriter
Describe your WHEELWRITER 5 SERIES 1 Problem * Need procedure to replace the Print Hammer Solenoid (1339328) On IBM Series I Wheelwriter 5 please... J.R.
  • CROSSTHREAD
    CROSSTHREAD Jan 04, 2011
    Read the question again. I didnt say "Print Hammer", I said THE SOLENOID (and gave the part#). It's not firing. It's dead.
    Problem Solver:
  • 6 Answers
I measure 3.3 Ohms on the solenoid and about 2.4 volts when typing. Anyone know the proper Ohms for the 1339328 Series 1 solenoid ? 3 Ohms sounds low to me. It draws .7 Ampere at 2.4VDC
UPDATE Oct 19, 2016: (those reading above are normal)
OK so I originally tried adjusting the head. I replaced the print cap (which looked OK but I figured maybe was worn down a bit), no luck. I then replaced the hammer even though I was not convinced of an issue. That did not work. I then took my time and slowly adjusted the striker adjustment (where the hammer touches) and that solved the problem. These machines are work horses and the answer is usually simple. Like mine was just an adjustment. All said, it learned a bit about this and hopefully now others will to. There is minimal information out there on the inter-net. I guess most folks are not using typewriter any longer.
Posted on Aug 13, 2016
  • Lexmark Master
  • 3,594 Answers
Not likely that you need a print hammer. You may need a plastic print solenoid cap. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Jan 04, 2011
  • Joe Bit
    Joe Bit Apr 10, 2017
    Unless your pint hammer CAP is cracked or severely worn you probably do not need that EITHER. $20.00 for a piece of plastic is just crazy. try adjusting the hammer on the opposite end of the plastic striker. It works.
The hammer does not strike on the platen
You need a print solenoid cap. We sell them with instructions for 20.00.
DickyO
typewroterguy@att.net
Mar 09, 2015 | IBM Wheelwriter 10 Series II Typewriter...
Ibm wheelwriter 6 Series II
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Apr 28, 2014 | IBM Lexmark Wheelwriter 6 Series II
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
Ibm 6747 w'ont write (hammer w'ont hit)
Jan 16, 2014 | IBM 6747 refurb typewriter wheelwriter 6...
Show me where the solenoid is on the IBM Wheelwriter 10, Series II typewriter
If you are asking about the print solenoid. Remove thr ribbon, below the ribbon just inside thr L. printer frame. It's about an inch & 1/2 in diam. and about 3/4 inch thick and silver.
DickyO
May 22, 2012 | Lexmark Wheelwriter 10 Series II...
Replaced cartridge on IBM wheelwriter 5.Won't type now.
If the print hammer isn't hitting the printwheel and platen the plastic print solenoid cap is probably broken. We sell them with shipping ans instructions for 20.00.
DickyO
216-241-0027
May 10, 2011 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 series 2.
Put in a multi part form and type if the print is good on the carbons the problem is ribbon or ribbon lifting, if the print is poor the print solenoid cap is probably cracked. We sell the cap with instructions and shipping for 20.00.
DickyO
216-241-0027
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
Jul 14, 2009 | Lexmark Wheelwriter 10 Series II...
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5
Get a new laser printer, or even inkjet. They can be had for under a hundred bucks. It'll cost you that to get someone old enough to know what a wheelwriter is to come and look it...
Jan 08, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 5 Series II Typewriter Logo
527 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
