Question about Maytag Refrigerators
Maytag MTB2156DEW not cooling. Lights work. Icemaker has never been hooked up but is clicking -- not sure if there is a connection or not. Coils have been cleaned. No fans are running. Only a very tiny bit of ice on lower part of evaporator coil.
Cerfer39
  • 709 Answers
SOURCE: Evaporator coils icing up
Hi Jijm,
The time is really fast for the Evaporator to be freezing up like Sparkgap said. A possible solution is that you Defrost heater is burned out. It is usually located at the bottom of the evaporator encased inside a Glass Tube with a wire connected to both ends. If you have already accessed the Evaporator coils look for this heatrer and remove it for examination. What I find is the heater is usually burned in two. You can use a Volt ohm meter to check the resistance across the two connections, It should read less than 20 ohms. You can get another heater at www.repairclinic.com. Since you are icing up so fast, you might have your thermostat for the freezer set to wide open making it run all the time to gain the coldest temp possible. Please do not knock what Sparkgap said as you could have some moist air getting into your freezer through the door seals. If your heater is ok, then it may be the Defrost temperature sensor. This is unlikely, but still possible. I am not familiar with the Amana fridge so I am not sure where this sensor is located. It does have to be somewhere around the evap coils.
Posted on Nov 08, 2007
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Maytag side by side freezer drain icing
This is a pretty common problem. Sometimes the defrost cycle is not long enough because the freezer setting were too low. But most times this begins slowly until the drain finally closes and then the water has no where to go but the inside of freezer or refrigerator. I have more help topics to prevent a constantly happening over and over again. But you may have a blockage down-line from the freezer. So until you can melt the ice and pour a warm solution of water and clorox in the drain and it end up in the pan below the refrigerator I will hold off on that until I hear back from you, Thanks, Sea Breeze
Posted on Jul 14, 2009
  • 1891 Answers
SOURCE: frezzer compartment coils iced up and fan not running?
ck for bad defrost thermo ( i would just repllace it with new . this will correct problem most of the time .. mm
Posted on Apr 19, 2010
SOURCE: Evaporator coils freezes to a block of ice is this
Time for manual defrost. Empty, unplug, clean, let sit for 24 hours. Heater becomes overwhelmed with ice and cant work. Cause? Door being held open too long or bad door gasket/ gasket not sealing. If it freezes up again and you know non of the above has happen, then its time to buy a heater and or thermo sensor.. try it. It worked for me and saved big bucks.
Posted on Jun 17, 2010
I have a 5yr old MBL2562HES. I quit cooling and freezing. It is blowing cold but will not get below 43/63. I removed the icemaker and removed the back panel in the freezer. The coils were not frozen...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | Maytag 22 cu. ft. Bottom Freezer...
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
Ice maker not producing ice. no water flowing to ice making unit. water coming out of dispenser
You have to hook the icemaker up to the electrical circuit powering your refrigerator. Make sure wiring is correct. Some time it won't work if there is a loose connection.
samsung fridge freezer
Oct 30, 2010 | Maytag Refrigerators
Clicking sound and lights flashing under water glass dispenser door panel
Just fixed this same problem today. It turned out that a tiny drip of water from the icemaker had formed into a glacier behind the cabinet back panel. It was frozen solid from just below the icemaker down to the cooling coils. Removed the panels, melted the ice, fixed the drip and we were back in business.
Good luck,
Brendan
Jun 13, 2010 | LG LSC27950 Side by Side Refrigerator
Our maytag refrigerator runs nonstop and doesn't get as cool, even after cleaning coils
Chek the interior lights. Make sure they are turning off. One bulb will cause these symptoms. Is the bondensor coil hot( it's the coil under the unit. If it is, The fridge is working but has a heat source that won't quit or run out.
Nov 17, 2009 | Maytag MZD2766GES Side by Side...
Icemaker quit working after I cleaned the coils.
After checking the fill tube (line that fills the icemaker) to make sure it's not frozen , pour about 3/4 cup of water into the icemaker . If the icemaker dumps the water but doesn't refill , replace the water inlet valve . If the icemaker doesn't dump the ice , replace the icemaker . ALSO , make sure the fan which cools the compressor is working . Possible when cleaning the coils , a glob of lint or something , was sucked into the fan and blocked the blade from turning .
Aug 04, 2009 | Whirlpool ED5FTGX Side by Side...
I have Maytag MTF1954ARA with ice maker which stopped working. Water is available, filter OK, Water inlet valve removed and tested OK. Is there something else to check before I have to remove/replace ice...
Pour about 3/4 cup of water into the icemaker . If it dumps the icecubes but doesn't refill with water , then replace the water inlet valve . If it doesn't dump the cubes , replace the icemaker . Make sure the coils are clean down by the compressor also .
Aug 02, 2009 | Maytag Refrigerators
No ice
You need to test the dual water control valve on rear of refrigerator with and ohm meter. Disconnect both sides from the power connections at the control valves. Test each coil with an ohm meter. You should get the same or close to the same reading on both coils. Let me know what your model number is and I will be able to tell you the part numbers, Thanks, Sea Breeze
Jul 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
I have a GE side by side refrigerator and I just replaced the defrost heater last week because it would cool and than freeze up and I would have to turn in off and defrost it myself. Now it cools and stays...
Icemaker solid:
This could be a problem with the icemaker not dumping the ice or with the water valve in back not shuting off completely.
Water in the floor:
This may be related to the icemaker but first check the drain under the evaporator coils.
Dec 15, 2008 | Maytag MSD2656G Side by Side Refrigerator
Ice maker motherboard
call the manufacture, sounds like an issue with the circuit board
Feb 19, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
70 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
