Question about Kenmore 22042 Top Load Washer
My 22042 wont start up,no display,nothing,if i unplug it overnite,sometimes i can get it to run for one load
Washer wont spin or agitate and when set to drain and spin immediately starts making a noise and doing nothing with lid closed or open. what could it be?
Sounds like a load out of balance. Try shifting the clothes then press the spin cycle. Sometimes unplugging the washer for a minute or two resets the timer. Are you over-loading with heavy items?
Feb 08, 2015 | Washing Machines
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I was drying, a load finished fine. Put the next load in, turned the knob for setting and I got the error code of "PR" and it wont turn on. The display is not working. So I unplugged it, then reset the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Electrolux Frigidaire Affinity AGQ8700FE...
I already cleaned out the carb. the mower will start then just stop a few seconds later
still sounds like not getting fuel ,did you soak the carb in something overnite,this is what I do ,sometimes just a spray out wont help.how old is mower?
Apr 22, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Kenmore 22042 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
