Question about Polaroid Televison & Video
Flat screen tv,,,,trying to hook up the directv...when i turn tv on, it says no signal. not sure why i cant chng channel?
    Master:
  • 691 Answers
There is nothing programmed in, you must do this first. Also have a good tuner or direct tv operates off of different channels it must be hooked up and on first and then programmed if you are trying that way, or use input jacks or HDMI if capable
Posted on Jan 02, 2011
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
Message "no Signal" when everything is hooked up.
You have a board that has malfunctioned if all your connections are good. Sounds like the 'Main Board' but there are other bosrds that can block the signal also. Hook it up with a different type connection and see what it does.
Col. Dana Gillespie
Dec 04, 2014 | Haier LEC24B1380 24" TV/DVD Combo - HDTV...
I cannot get the channel scan to recognize channel 3 to be able to watch directv
Make sure the direct TV is turned on and has a channel selected before running the auto scan. The TV won't see channel 3 if there is no signal there.
Oct 29, 2013 | Vizio Televison & Video
Hooking sayyo tv to directv
Not sure if I understand what is happening here but if set on channel 4 the connection for the direct TV would have to be to the coax fitting on the rear of the set.
For the audio/video inputs on the rear or side it would have to be the same ones coming out of the direct TV box to one of the same but inputs on the rear--Audio/video are one connection and coax for channel four is a different one.
Dec 22, 2012 | Televison & Video
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
right.
Nov 11, 2007 | RCA VR355 VHS VCR
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
Televison & Video Logo
120 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
