Question about Kenmore HE2 Plus Front Load Washer
Beeping DL - Kenmore HE2 Plus Front Load Washer
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
DL means door latch issue, I suggest you contact a service company, or if you wish to fix yourself, you can start here.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Hi iam trouble my server hp dl 380 g7 no dislpy continue sound beeb
i need to know how many beeps long beeps, short beeps,
both short and long beeps, and how many times it happens.
than email me and i will help you resolve the issue
thank you rod
Mar 03, 2015 | HP Computers & Internet
K8n-dl mb does not post. only action that comes is beep/beep off/beep/and on and on. This is with only one processor in and no ram. put pciexpress video card in and screen is blank. put second processor in...
The beep beep code is an audible code telling you that you have no Ram installed. You cannot run this board without system ram. Fit some system ram and connect a video card and a drive. Make sure both cpu's are fitted and try again. If it still beeps, note the length and number of beeps and go to the ASUS website. You can find the audible codes in the support section under bios fault codes..
Dec 23, 2009 | ASUS K8N-DL Motherboard
DL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Jul 27, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Start and after few minutes show "dl" f
easy fix, door lock failure, replace door lock asm. on old duet this part is same as GE, and samsung parts. new duets differ
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
