Question about Karcher K2.26 Electric Power Washer
Hi, My karcher k2.360 will not turn on. It is a new machine and has only been used 4 times and only for short periods.
    Problem Solver:
  • 3 Answers
I think the problem is a switch power knob!!
Posted on May 29, 2011
My karcher washer has lost most of its pressure it doesn't clean the bricks like it used to
The lance hose that attaches to the pressure washer keeps coming off when the power to the machine is turned on, i've only used this product four times since new in January this year.
Sep 06, 2010 | Karcher K2.26 Electric Power Washer
Karcher 360M pressure washer pulsating problem when idleing
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this. Hope this helps Kind Regards Brad
Dec 16, 2009 | Karcher PSI Electric Pressure Washer
After using the unit for a short period of time (30 mins) the motor will not restart unless ist setts for an hour or so.
hi
something is happening when the engine gets warm.try a new spark plug with the same heat range.
bye savumihai71
Sep 15, 2009 | Karcher 2500 PSI Pressure Washer
The engine on my Karcher K2.26 turns on when you turn the switch and continues to run rather than just when you pull the wand trigger. Lower pressure also results.Any solutions?
yea mate ya bypass will be stuck(the little valve that turns the unit on or off) also if not that there is a little micro switch attached to the valve this may of dislodged for some reason... commonly happens if unit has sat for a period of time not used
regards
brad
Sep 07, 2009 | Karcher K2.26 Electric Power Washer
Karcher k 2.36 smoking and flashes of light inside the machine.
Hi:
This sounds like a short circuit or motor problem. They are relatively easy to take apart. If you see a burned wire or connector this can be repaired. If not, it is the motor and probably too expensive to repair considering the price of a new one.
Jun 30, 2009 | Karcher K2.26 Electric Power Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Mar 07, 2009 | Karcher K2.26 Electric Power Washer
Trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Nov 09, 2008 | Karcher 2500 PSI Pressure Washer
Gaggia Syncrony Compact
If you are in decalcify circle you have to finish it before the machine goes to ready again.
When you decalcify the machine, there will comes water for a short period, then it hold up for a couple of minutes then it will run out little more water. So will the machine do to the water tank is emty.
May 18, 2008 | Gaggia Syncrony Espresso Machine
Karcher K2.26 Electric Power Washer Logo
395 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
