Question about Hunter (25417) Ceiling Fan
We are installing a Hunter the Waldon ceiling fan. the problem we are encountering is there are two white, two black and one green wire coming from the ceiling and the fan/light has a white, black black/white wire and a green wire. We can get the fan to work but not the light when we connect the green to green, all the white together and one each black from the ceiling to one black and the black/white from the fan. Help
SOURCE: trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
Posted on Feb 21, 2010
SOURCE: installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Posted on Oct 30, 2008
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 37 Answers
SOURCE: Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
Posted on Jan 31, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
Replacing fan. Wires from ceiling are grey pink white & bare copper. Wired to light switch. What wire connects to what? Ok so we just bought the place. The painters removed the old fans that had no...
Sounds like you have two hot wires. Just need to find out which wire goes to the wall switch. Try gray to black from fan,pink to black/white wire.white to white & green to green. If this doesn't work swich the pink & gray wires.
Feb 03, 2013 | Dryers
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
What is the whirring diagram
Most fans have 3 wires usually a white, black, and a blue(or black with white stripe) the white wire is the neutral and goes to the white wire in the ceiling box, the black wire is the fan hot lead and goes to the black hot lead in box and the blue(or other blk/wht) is for the lights and would go to the switched lead in the ceiling box(sometimes another color but not white or green)..if you don't have a switched lead coming out of the ceiling box and just two wires then the white goes to the white in the ceiling and both black and blue go to the black wire in the ceiling box
Jan 22, 2011 | Hunter 21617 Palermo Ceiling Fan
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Installing remote control ceiling fan
Your black wire is line and red is load. So your incoming power hot goes to black and out going power to fan connects to red. White is wired with all three whites together and same with green.
Aug 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Installing a universal remote on a ceiling fan.
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
I have just purchased a hunter heated Ceiling fan (Hunter 45003-01). The wires in the fan do not match the wires in the instructions. From the Fan assembly there are green ground black white From the...
hi thanks for the question the white wire is common the red & black are live join the red & black with a wire nut now you have really 2 wires thanks the appliance doc
Sep 27, 2008 | Hunter Heating & Cooling
Wiring connection ceiling fan
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hunter (25417) Ceiling Fan Logo
459 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
