Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I recently installed a Honeywell RTH6350D to replace a 2 year old LUX and can get everything to work but the heat(reason for replacing the LUX). Works sometimes but not consistantly. Have the common red(R) with jumper to RC, white(W), yellow(Y) and green(G) wires in play but do have black, blue, brown and orange available but have always been taped off to my knowledge. Please advise to how to get the heat on consistantly.
R represents power supply for the heat system.
RC represents power supply for cooling system.
G represents fan (neutral).
W represents heat system.
Y represents cooling system.
Y2 represents 2nd stage cooling.
W2 represents 2nd stage heating.
AUX represents heat pump.
Try calling 1-800-468-1502.
Their english is "REALLY BAD"!!!
Posted on Jun 09, 2011
  • 1,420 Answers
Try removing all wires but R and W. These are the only wires you need for heat. The others are to power the thermostat and AC. If the thermostat gives better performance, you have a drain from the other wires. Check to see if you have good connections at the furnace.
Posted on Jan 02, 2011
How do I change Honeywell RTH6350D thermostat from Celcius to farenheit?
yourhome.honeywell.com/home/Products/.../RTH6350D.ht
Operating manual.
May 27, 2014 | Honeywell RTH6350D1000 5/2Day Prog...
HONEYWELL RTHL2310/RTHL221 THERMOSTAT AIR WILL NOT COMEON
Recheck your connections.The wire colors may not have been wired in the standard way when HVAC system was installed. I remember the instructions on my Honeywell thermostat(replaced mine about 2 months ago) stated that you should look at the wire LOCATIONS on the 'stat you're replacing and tag the wires according to this,not the wire color(too late in your case).You'll have to verify the wires.Disconnect them(don't worry about noting where they were as it's not right anyway).Using an A/C voltmeter,locate the hot feed to the 'stat(ground one lead of the meter at a nearby outlet and look for 24v on any of the wires).Tag it as "feed".Now,touch this to each wire until you find one that turns on the ventilation blower and tag it.Try the other two,one of them should turn on the outside A/C condensor unit(this is the A/C wire).The remaining wire's gotta be the furnace,but verify anyway.This should be enough to get you back on track(don't feel bad,the instructions in my 'stat confused me a little,even though I've replaced mine a couple times before).PS- I think the blower fan wire goes to the terminal with the little factory jumper wire-this is so you can set it up to run the same fan in heat or A/C(factory setup) or remove the jumper to run a seperate fan for each(highly unusual setup but possible)
May 25, 2012 | Honeywell Programmable Thermostat Heater
Installed a Honeywell RTH6350D...no heat. I think it has to do with the wiring. Old round unit has red, white, and blue wires. Hooked up red and white but am not sure what to do with blue. Help!
normally there are 4 wires.. should be red to red which is 24 volt
green to g which is fan
white to w which is heat
and the blue could be used on y terminal for cooling
see try that and see if it helps....
Nov 29, 2011 | Honeywell Programmable Thermostat Heater
I replaced an old mercury T-stat (York with model number 2TH11704024) installed a new T-stat (RTH6350). The wires that I I have are O (orange), G (green), Y (yellow), T (gray but not used in new T-stat),...
Did you shut the power off to the air handler/furnace...... before you installed the new thermostat??? You may have shorted out the transformer or blown the transformer fuse...... If you try to put the Fan switch on the stat to Fan ON does the fan come on ..... if it does the transformer is OK.. On the new thermostat did you program it to tell it that you had a heat pump system ???? Looks like you had it wired right. Here is a pdf manual for a RTH6350 http://customer.honeywell.com/techlit/pdf/PackedLit/69-2416ES.pdf
Its on page 13 Advance setup for tell the new stat that you have a heat pump....There is also a Honey well Hot line on page 2 Hope this helps.
May 01, 2011 | Heating & Cooling
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,254 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
