Question about Matrix 226R (VPR226R) PC Desktop
The power switch on the front no longer works. Where do I get a new one?
    Scholar:
  • 149 Answers
Check the cable where it connects to the motherboard. Check the cable where it connects to the switch, resolder any loose connections. Usually these do not break easily, but if it is broken you can buy a generic switch at newegg (http://www.newegg.com/Product/Product.aspx?Item=N82E16812201029&cm_re=power_switch-_-12-201-029-_-Product)
Posted on Jan 02, 2011
Systemax SYX-SBT-X58 desktop.Is there a front power switch part for tower or another alternative available?
I can't see how holding the button a little longer would make any difference, the button press sends a quick little signal to start the BIOS operating system built into your motherboard. Maybe you just need a new switch as it could be shorting somewhere when you press it a certain way. You can remove the wires from the back of the switch and touch them together to see if the pc starts. If that is too complicated then i would suggest taking it to a store before any real damage is done.
Dec 15, 2017 | Systemax Computers & Internet
Power button broken on Norelco 7825xl shaver - Can't turn on... Button has actually fallen back into the shaver itself, and can no longer be reached to depress - to turn on or off. Help... i love this...
The specific part you need is no longer available. However, the part linked here at shaveroutlet.com will work with your model also. The entire switch button is included. The light display just wont work properly
Philips Norelco Front Body Housing with Switch Button for Quadra 7865XL
Jul 12, 2016 | Norelco Health & Beauty
Front blower motor town country intermitantly stops working. Rear blower works fine.
Most likely the motor is going bad, but it could be the switch. If fiddling with the switch will make it work sometimes, replace the control panel. Otherwise, replace the motor.
Jan 10, 2018 | 2001 Chrysler Town & Country
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
I have an RCA rear projection tv. The model number for my unit is P56923BL. The service number is P56923BLYX1. The TV Serial Number is 851251224. The inside Component Assy Serial Number is 8512512243....
Most of the keypad malfunction is caused by dirt build-up inside the tact switch. Because of that the contact can no longer function. Electrical contact cleaner can clean it by directly spraying into the switch.
Another option is to replaced the tact switch with new one. It will not cost you much because it is one of the cheapest parts. Click this LINK to have an idea what the tact switch is. Check the actual switch installed in your unit before ordering.
If you don't know how to solder and desolder it from the board, click the link below for more info.
Soldering tutorial
How to desolder parts
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 28, 2011 | Televison & Video
Driver's side power window will not go up or down. I believe that the switch is no longer working. How do you swap out the switch?
Common problem for 2000-2005 Impalas. Mine went bad a year or so ago. Available on Ebay. Go new, not used. Or you can do what I did. Get a new one as back-up, took mine out, cleaned the contacts, put it back together, and resold my new one.
Anyway. There are two screws in the pull pocket rear of the switch. Remove screws and lift the rear end of the cover and unhook the front. Unplug the window and mirror plugs. The switch can be unclipped from the cover.
Aug 24, 2010 | 2002 Chevrolet Impala
D845PESV system no longer powers up, but a green LED is on motherboard, no fans or drives turn. Got new power supply, same conditions occur. Front power switch has continuity when depressed. Is there a...
It might be a problem in the motherboard in the circuit, it can also be a problem from the RAM check it with a new RAM. RAM frequency must be matched with the motherboard specified frequency.
Jun 29, 2010 | Intel D845PESV Motherboard
The heated dry button will no longer work on my GE Mono. dishwash
most often they are one unit or "circuit board" and you will need to replace every thing, if you can turn off power and take off front door panel you should be able to "see" switch componet or look in your owners manual ...hee hee
May 21, 2009 | GE Monogram® ZBD6880NSS Stainless Steel...
Matrix 226R (VPR226R) PC Desktop Logo
60 people viewed this question
Top Matrix Computers & Internet Experts
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
