Question about JoWood Productions Transport Giant Gold Edition for Windows
I have just installed transport giant gold edition on my new hp windoew 7 computer but when i try to run it it says please diable debugging or anti- virus software. why and how do i do this please
How to load flight simulator x gold edition from my old crashed pc to my new window 10 pc
Have you check the drivers and compatibly?
For your question, I suggest updating the graphic card driver and BIOS from the manufacture's site, also please right click the install file and choose run as administrator. If the issue persists, try to turn off UAC.
Sep 11, 2016 | Microsoft Flight Simulator X - Gold...
64 bit interactive
Change the startup shortcuts properties so that it runs in compatibility mode for windows XP.
Dec 16, 2013 | JoWood Productions Transport Giant Gold...
Computer runs slow, becomes unresponsive or just freezes or crashes, unable to free up hard drive even with defrag. Unable to access the web sites as thought the keys are not sending the commands at times.
Sounds like you need some house cleaning. Try freeware programs, CCLEANER: http://filehippo.com/download_ccleaner/ clean the junk using the cleaner, then use the Registry cleaner to remove the junk from the registry, delete all. In the TOOLS section, select STARTUP, disable ALL unnecessary startup programs. Select Internet Explorer, disable ALL toolbars and unnecessary add-ons. Use MALWAREBYTES freeware to scan your laptop: http://filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the Free Trial Pro, you want the freeware version. Run a Full scan, delete ALL results, reboot. Run a full scan with your up-to-date Anti Virus software. With the specs you have on the HP there is no reason for this, other than to many thing are running (services) and possibly malware, toolbars, virus, etc. Take a look at this: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332
Sep 24, 2013 | HP new HP Pavilion dv7-6187cl Notebook PC...
I install Rome total war gold edition on my pc .Ihave wndows 7 ultimate 64bit .When i am starting the game ,it crashes .I wonder if there is a solution on this problem .
as you have windows ultimate, you might want to get yourself XP mode and try running the game in that. get it from here: http://www.microsoft.com/windows/virtual-pc/download.aspx
Jun 18, 2011 | Sega Rome: Total War Gold Edition for...
Every time i get to a certain part in re5 gold edition like chapter 3-2 or 3-3 when you fight the giant sea creature, it says game corrupted. I deleted and started over and when I get there again, it says...
Your disc is probably scratched or dirty. Try to clean the disc by wiping it with a dry microfiber cloth away from the center. You can also try some of these tips from WikiHow.
If you game is new and all else fails, try to return it.
May 19, 2011 | Capcom Resident Evil 5: Gold Edition for...
I've installed Civilization III Gold Edition on my computer, and it is not working properly. How can I make it compatible with Windows 7?
Right Click the shortcut to run the game, click "run as administrator" and "run in compatibility with windows xp"
May 07, 2011 | Sid Meiers Civilization III Gold Edition...
I had an application called "creatacard gold 3" on my old computer with xp. I have all my important information from past 10 years is on that application. the computer crashed and i needed to buy a new...
The CreateACard Gold 3 (CAC Gold 3) will never work with Windows 7 64bit unassumingly because the software producing company has not upgraded their software for even Vista 64bit.
I recommend you to switch to " Hallmark Card Studio Special Edition" it has all the features of CAC Gold 3. You will enjoy it as there should be no problem installing it with Windows 7 64bit.
Good Luck!
Sep 21, 2010 | Computers & Internet
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
How to disable firewall connections on an HP
As its HP im guessing you will have Nortons Anti Virus Running On The System, If You Left Click This For A Minute And Press Disable That Should Disable Your Firewall.
Also have you tryed to run itunes, as once that is installed your firewall should let you gain access to the Ipod
Feb 16, 2009 | HP Pavilion A1130N Athlon 64 3500+ DVD+RW...
JoWood Productions Transport Giant Gold Edition for Windows Logo
207 people viewed this question
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
