Question about Intel D845GVSR Motherboard
Mother board D845GVSR
Power supply is correct jumpers are in correct position although not switching led board glows
  • Matt Major May 11, 2010
    so the pc will not boot? What error message do you get?
  • 80 Answers
Hi im wesley. does the pc boot up at all?
Posted on Jul 21, 2008
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Hp D 530 - DK907T 902-FAN COMMAND 2 PIN CONNECTOR FROM POWER SUPPLY NOT CONNECTED NB i've changed the chassis it was SFF ans i 've changed in Tower with a standard power supply
Maybe you put the wrong jumper of the power jumper for the front panel.
Explanation:
You can see the switch to turn on the PC right, then make sure that switch correctly installed on the right jumper on the board. Follow the cable to attach to the mother board.
Aug 22, 2011 | HP Compaq Business Desktop d330 Slim Tower
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Same problem with my D845GVSR
turn off power and reinstall the jumper in normal mode position
Oct 02, 2009 | Intel D845GVSR Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
I have adell 865 mother board but i am not broken that cimos pass
if u need totally clear the cmos/bios and back to original settings remove the AC power supply then remove the make a short the jumper settings at 5 seconds.the put it back the battery and the original jumper...Thanks and Good Luck...^_^
May 13, 2009 | Intel D845GVSR Motherboard
My mother board is intel 845GVSR.msg displays turn off the power and reinstall the jumper in normal mode position
Did you short the BIOS memory? In that case it hasn't been put back properly.....sodeep
Apr 18, 2009 | Intel D845GVSR Motherboard
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
108
Jul 08, 2008 | Intel D845GVSR Motherboard
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
Intel D845GVSR Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
