Question about Sony str-4800sd stereo receiver with manual
Power out rms- 4 o 8 homs? - Sony str-4800sd stereo receiver with manual
  • 3 Answers
The Sony STR-5800 is listed as 55 Watts per channel into 8 ohms, so I presume the same vintage STR-4800 would be 35 Watts per channel into 8 ohms (x4 channels = 140 Watts). Most home audio speakers have 8 Ohm impedance.
The STR-5800 specs list 4 Ohm to 16 Ohm speaker capability, but I don't see any corresponding specs for the STR-4800. Be careful, if trying to drive 4 Ohm (car) speakers, this may possibly burn out the STR-4800 if it isn't built to drive the lower impedance speaker.
Posted on Jun 19, 2014
    Brigadier General:
  • 8,546 Answers
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Posted on Jan 03, 2011
What number should i set on each channel running behringer vp1220 speakers
Go to owners manual in the specifications page.
Will show the impedance, you should mach the impedance output with the speakers,2,4, 8 Homs impedance and how many watts RMS or peak.
Oct 11, 2012 | Behringer EUROPOWER EP2500 Amplifier
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
I dont know how many watts it is
4 Ohm Stereo Power (RMS): 250W X 2
4 Ohm Mono Power (RMS): 850W X 1
2 Ohm Stereo Power (RMS): 450W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 16.93"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
Whats the specs
  • Bridged Max Power: 520 Watts
  • RMS Mono: 170
  • Variable Low Pass 40Hz-120Hz
  • Variable Hi Pass 150Hz-1.5Khz
  • THD: 0.02%
  • Die-Cast Aluminum Heat Sinks
Sep 20, 2010 | Power Acoustik XL2-520 SPL Car Audio...
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
Whats is the rms at 2 ohms and rms at 4 ohms of m1900xe MA Audio
what is the amplifier model number and how many channels does it have... if you can just read off the numbers on the top of the amp...
Dec 12, 2009 | MA Audio M1900XE Car Amp
How many watts dose a concept cc-752L amp have ?
4 Ohm Stereo Power (RMS): 75W X 2
4 Ohm Bridged Power (RMS): 250W X 1
2 Ohm Stereo Power (RMS): 125W X 2
Sep 26, 2009 | Concept (CC752L) Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Amp Will Not Stop Overheating
You say you have 2 p312d2 subs. Ok so the d2 stands for dual 2homs (2 X 2homs voice coils per sub) , conecting in parallel the 2 voice coils of only one sub will create 1hom load to the amp, and if your amp is 2homs stable per chanel that means you are lowering too much your homs causing the overhwating to it.
Sep 25, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Sony str-4800sd stereo receiver with manual Logo
144 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
