Question about Epson Stylus C88 InkJet Photo Printer
Hi, I haven't used the printer in quite a while. I've checked the ink and put in some new ink but the printer is giving me the message: Head cleaning cannot be completed. How do I clean them by hand?
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
kevin000
  • 1847 Answers
SOURCE: epson 1280 wont print
hi i was tring to chat with you where u getting my messages
Posted on Jun 08, 2008
  • 110 Answers
SOURCE: Printer won't respond
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Posted on Aug 22, 2008
SOURCE: Canon MP600
manleeroas, not that it will help but try a few drops of isopropyl alcohol. directions given at this link:
http://www.ehow.com/how_2078853_clean-clogged-inkjet-print-heads.html
Posted on Sep 06, 2008
SOURCE: Epson R230 ink & Paper Lamp Blinking
could someone show us how to open the r230? im having hard time cleaning the waste ink pad because i cannot open the r230..
Posted on Oct 27, 2008
The head cleaning cannot be completed by the printer?
Epson printers use a lot of ink to do head cleaning. If you're low on ink, it will give you that message. Put in new ink carts, and head cleaning will happen. You may want to purchase "cleaning carts" that have a special solvent to help un-clog the print heads.
Sep 11, 2014 | Epson Office Equipment & Supplies
MFC-J435w when trying to print I get error 5A Help?????
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Aug 01, 2017 | Brother MFC-465CN InkJet Printer
I have not my Epson Stylus Photo for quite some time. Now I want to use it again, I 've put in some new cartridges. The print shows repeating (green) lines. Any idea what could be the problem ?
To help complete the pattern, feed copy papers to the printer and do atleast 40 blank photocopies and afterwards clean the head and check the nozzle.if it has not improved, repeat the same procedure until the pattern completes.mine also had the same problem but after doing that, it was solved for good.
NB: Command copies without putting any printed paper to save ink.
Oct 12, 2012 | Epson Stylus Photo R220 InkJet Printer
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Cant print
Ink button on? Check status monitor? I think is ink out message. Head cleaning for several time, throw ink too much. If u don't use CISS, after instaled ink tank, just wait for 1 hour before use printer. Ink will flow to head itself.
Jun 12, 2009 | Epson Stylus C43UX InkJet Printer
The magenta ink won't print & it's not the cartridge
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning". The nozzles on the print heads are finer than a human hair, even if you could get at them without a major strip down I wpouldnt recommend it as they can easily be damaged.
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 07, 2009 | Epson Stylus C66 Photo InkJet Printer
Ink has run out message
Ink not made for your printer has risks. 20 years as Canon rep taught me this. Yields: are affected by resolution, type of paper, condition of print head, condition of ink jets, all ink jets and lasers are mfg'd under lisence to Canon. You have the best! Anytime supplies are cheaper, something is left out. used cartridges usualy leak air and drip ink ck for stains under print head. cartridge has used blotter also drips. Cheaper cartridges contain less ink, no free lunch. Fill it yourself 1 or 2 times and do it right. Put the printer in your shower for twenty minutes if you see excess leaked ink. Allow to air dry for a few days then install new cartridges. Run all the Nozzle checks and print head utilities. Touch nothing else on the inside. This will fix it or f@#%k it up for good
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus C88 InkJet Photo Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
