Question about Dryers
Magic chef propane dryer. Burner comes on but quits after 10-15 seconds.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have a defective gas light sensor, that needs replacement.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
I want to convert my magic chef kitchen stove..model number, 31001saw from gas to propane..how much is the conversion kit and a good site to buy it from..?
There's not much difference except in the pressures of the gasses. The PROPANE must have a round attachment that controls the pressure of the gas, is inline, usually close to the tank. On the top of that device, valve, is a screw-type mechanism, often covered by a flat piece of plastic that can be gently pried off. If you research, you'll find how much to turn that set screw, and in what direction. It's quite easy.
Dec 08, 2015 | Magic Chef 31000 Gas Kitchen Range
My gas burner comes on and goes for about 30 seconds to a minute and then shuts off and then 30 seconds or so later will come back on
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 24, 2010 | Magic Chef CYG2000AWW Gas Dryer
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
Coversion
all i for sure is that for propane gas you will need smaller burner jets because of the higher pressure. ive done this the other way around, converting from propane to natural gas by drilling the jets bigger with tiny drill bits
Aug 01, 2009 | Kitchen Ranges
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
We own a 1973 TravelEze travel trailer with a magic chef lp 4 burner range. The model number is unreadable. It does start with BT22 we think. We would like to order a replacement gas regulator and a m
I think you should have more numbers. there are quite a few other series for this unit. I have posted a site below for your assistance.
http://www.aaarv.net/bt22_series_parts.htm
Please rank if this helped
Apr 27, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
We are switching from Propane to natural gas and the stove didn't come with orifices and a manufacturer said that it didn't need them that they could be adjusted. they didn't tell us how. Its on a Magic...
Hello dradon,
Welcome,
You said,we are switching from Propane to natural gas and the stove didn't come with orifices and a manufacturer said that it didn't need them that they could be adjusted. they didn't tell us how. Its on a Magic Chef 3110PRW
I am glad you asked us before attempting to do this change!!!!
This is something that should be done by a qualified gas technician due to safety concerns.
Here is a number that you can call to see if there is a kit available for your model.
Magic Chef
Customer Experience Center US 1-800-688-9900 Canada 1-800-688-2002 or Consumer Parts Dept 877-232-6771
I'm glad I caught you before you started.
I know of some tragedies from this!
Huuum
Oct 16, 2008 | Magic Chef Kitchen Ranges
Dryers Logo
35 people viewed this question
Top Dryers Experts
