Question about Watches
Do i set the numbers or the big hand?little hand and how do i do it
When it is six-thirty, how many minutes must pass
One minute. The minute hand makes one revolution of the clock or watch dial every minute or 60 seconds. When it is 6:30 exactly, one minute later, the minute hand will pass by the six again.
Aug 28, 2014 | Watches
Replace fossil big tic battery
Little battery operates the analog. big battery operates the digital second hand on the fossil big tic.
Aug 19, 2013 | Fossil JR8096 Wrist Watch
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
I cannot set the calendar for this watch...can anyone help me?
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
Jun 28, 2010 | Timex T Series Perpetual Calendar #T2M458...
I can't set the time on my pod radio controlled watch,the time is correct but the little and big hands show a different time.
Read the manual, or just mess around with it and press every button you can, then it is bound to do something. Let me know if it works!
Oct 15, 2009 | Bulova Watch
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
What are the numbers on face plate for(likes 60,65,....900,1000)?
The ones associated with the little circles? One dial is for seconds, one for minutes, and one for hours. The seconds one should be applicable for time. The minute and hour, along with the big seconds hand that is centre mounted are for the chronograph function.
Jan 23, 2009 | Tissot PRS 200 Wrist Watch
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
Dec 25, 2008 | Fossil CH2470 Watch
Hour hand incorrectly positioned
hi Jim the hour hand is easy to be fixed but by pro qualified , it is a matter of little drift to back words so don't worry for the 100 Mwater resist if the person opened the back cover of the watch then he have to replace the rubber belt at the border of the cover case and then evry thing for the water resist will be good regards , and plz don't forget to rate , remember i am here for help thx
May 08, 2007 | Timex Expedition® Outdoor Casual...
Problem with second hand
I need to know what type of oakley is this .. i mean what model .. because they have different specifications..
Dec 26, 2006 | Oakley GMT OAK0531 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
