Question about LG DLE5977 Stainless Steel Electric Dryer
My LG DLE5977W's drum will not turn, and makes hmmmm when I hit the start button. I can turn the drum manually; power is good as it lights up; lint is cleaned out also;
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
Our LG DLE5977w dryer doesn't dry our clothes. The drum turns and there is heat, but it seems there is no air flow. We checked the vent hose and no clogs. When we cut it on the "drying"...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 18, 2011 | Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
I have a LG dryer dle5977w and it has started making a rattling noise it is coming from the bottom left side by the lint fan does any one out there have a idea of what it might be
May be a small sock or dryer sheet caught in the blower wheel.
Remove filter and use a flashlight to see down the filter housing. You may be able to see item.
Rotate the drum each way by hand to help see item.
Remove with hooked wire hanger.
You may need a service call to remove object.
Jan 04, 2010 | LG DLE5977 Electric Dryer
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
Lg washing machine drum light stays on and wont let me turn the
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
May 15, 2009 | LG Washing Machines
Drum light stays on and wont let me start it again. Its dead but has light.. I have to power down the entire house to get it to start again
I had the same problem. LG addressed the problems as follows:
1. Unplug the unit 2. Press and hold the power button for 10 seconds. 3. Plug the unit back in.
It WORKS!! It's like reseting your computer or alarm clock. You've got to kill the power and press and hold the on button while it's still unplugged.
Hope this works for you.
May 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm DLE5977W Dryer about 1 1/2 yrs old. Running small load on normal and we heard a funny clunk noise and than the dryer shut off. When i went to look, power was still on with 20 min. left on timer....
3 screws on back of dryer to remove the top. Top slides back about 2 inches and lifts off. Dryer drum should have a thin drive belt around it. Pull on belt. If broken you will know. If loose, then it's off pulleys. Sounds like a broken belt. Check repairclinic.com or appliancepartspros.com for dyi videos on how to replace.
Mar 27, 2017 | LG Dryers
LG DLE5977 Stainless Steel Electric Dryer Logo
345 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
