Question about Video Game Consoles & Games
Whilst using the free-step in the aerobics section, the counter on the left of the screen doesn't register the total steps. I count my steps, and the counter will go accurately for a while and then stops for about 6 of my steps, and then goes slowly, and then will pick up again. I usually do at least 800 steps, but in 'go slow' mode, will only register 400-600 steps, and the 'coach' will tell me to speed up or keep with the rhythm, when I'm going max speed, and staying exactly with the beeps! Is there a solution? I've only had my unit since just before Christmas, and I LOVE it, and enjoy all the challenges. Lynne Whittingham
  • 210 Answers
SOURCE: longest 6 minutes ever
Check your complete venting system to make sure it is not clogged. Use a nylon scrubber to wipe down the 2 sensors as they can get coated with fabric softener, and clean your filter as it can get clogged too. To test it run it under water to see if the water goes through or pools. Use hot water and mild soap to clean it. I have heard some people put it in there dishwasher to clean it.
Sgt 48
Posted on Jun 07, 2008
  • 3 Answers
SOURCE: step aerobics
For wiifitboy and bsnyder = Make sure the power button is facing the back of you, away from the tv!
Posted on Feb 12, 2009
here2helpBSH
  • 27 Answers
SOURCE: Bsoch dishwasher runs long and displays 1 minute left on timer
sounds like a bad solder connection on the heater relay of your control unit. more than likely you will need a new control unit. part number 266746
Posted on Mar 19, 2009
  • 95 Answers
SOURCE: Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Posted on Aug 01, 2009
SOURCE: pick up line ringing Dterm 80
Line ringing preference on our NEC phone
Do not get outside line, just press:
#7579 to turn on, #7576 to turn of
Then press SPKR to exit
Posted on Mar 22, 2010
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
Can i check on my on line purchases for the last month?
A pedometer or step counter is a device, in modern times usually portable and electronic or electromechanical, that counts each step a person takes by detecting the motion of the person's hips. Because the distance of each person's step varies, an informal calibration performed by the user is required if a standardized distance (such as in kilometres or miles) is desired.
Used originally by sports and physical fitness enthusiasts, pedometers are now becoming popular as an everyday exercise measurer and motivator. Often worn on the belt and kept on all day, it can record how many steps the wearer has walked that day, and thus the kilometres or miles (distance = number of steps × step length). Some pedometers will also erroneously record movements other than walking, such as bending to tie one's shoes, or road bumps incurred while riding a vehicle, though the most advanced devices record fewer of these 'false steps'. Step counters can give encouragement to compete with oneself in getting fit and losing weight. A total of 10,000 steps per day, equivalent to 5 miles (8.0 km), is recommended by some to be the benchmark for an active lifestyle, although this point is debated among experts[1][2]. Step counters are being integrated into an increasing number of portable consumer electronic devices such as music players and mobile phones.
i dont think you can your online purchases with it
If you are satisfied with my answer please vote three thumbs up.Thank you
Dec 03, 2010 | Exercise & Fitness
How do you get a total page counter
open the front door and look under the toner/drum section built into the copier (bottom left hand sie of the copier frame inside the door) There is a meter there that gives total count
Sep 17, 2009 | Panasonic Workio DP-2500E Copier
Reset maintenance counter
To reset the Maintenance counter yiu need to go into Config Mode.
Power on the printer while holding the 2 & the 6 button.
You will see the maintenence counter and can reset it from there.
May 27, 2009 | IBM Infoprint 1570 MFP - multifunction ...
On some aerobic games, particularly the step aerobics, it does not register my footwork correctly, and on the moves where you lift your foot up it will not recognise that at all.
Make sure that the balance board is set up where the blue power button is facing AWAY from your Wii/TV.
If it is set up correctly, then run a diagnostic on your balance board (see instruction booklet).
Regrettably, these boards have a bit of a history of one of the 4 sensors going out. If this is the case, then ensure your product is registered at www.nintendo.com and contact their customer service department.
Apr 08, 2009 | Nintendo Wii Fit for Wii
How do I use the stopwatch on iPod nano?
"iPod Software 1.0 for iPod nano introduces a Stopwatch feature. You can use the Stopwatch as you exercise to track your overall time and, if you're running on a track, your lap times too. The Stopwatch menu is located in the Extras menu. To access the Stopwatch from the main menu, select Extras, then Stopwatch, and then Timer (Extras > Stopwatch > Timer) to see its display. Total time of session Current lap time Left button (Start function shown)1 Battery indicator Right button (Clear function shown)1 The left and right buttons' names and functions will change, depending on the current state of the Stopwatch. Using the Stopwatch When you first enter the Stopwatch screen, the left button is labeled Start and the right button is labeled Clear. To use the Stopwatch, select the Start button (use the Click Wheel to highlight the Start button, then press the Center button). The Stopwatch creates a new session, and both the total time of the session and the current lap time begin counting: When these counters begin, the left button changes to Pause and the right button changes to Lap: If you select the Lap button, the current lap time will be recorded in the session's log, then the Stopwatch resets the lap time to zero and begins counting the new lap's time. The total time of the session will freeze for 5 seconds after you select the Lap button so you can quickly view your total time at the end of that lap. After 5 seconds, the total time of the session displays the correct total time and resumes counting. If you select the Pause button, both timers will stop counting and the left and right buttons will change to Resume and Done, respectively. If you select Resume, both timers will begin counting again. If you select Done, the Stopwatch records all the final times and creates statistics for your session in a log. Please note that selecting the Done button does not reset the display. You will see the final times for your total time and lap time displayed: To reset the display, select the Clear button (appears after you click Done and then select Timer again). Stopwatch Behaviors You can play music and use the Stopwatch at the same time. When iPod nano displays the Stopwatch screen, the Play/Pause, Next/Fast-forward, and Previous/Rewind buttons control music playback as usual. If you're playing music, you'll see an icon in the upper-left corner of the Stopwatch screen that indicates the current playback state: A play icon indicates that music is currently playing. A pause icon indicates that a song is currently paused. You can use the Menu button and the Click Wheel to navigate to other menus without interrupting the Stopwatch. Note: The Stopwatch will prevent your iPod from sleeping if it's counting. The Stopwatch will automatically stop if any of these three conditions are met: The total time counter reaches 24 hours iPod goes into hibernation (you can start it again when you wake iPod) You conne
Sep 28, 2005 | Apple iPod nano
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
