Question about York Exercise & Fitness
Can someone help me,,,,my mega max 3001 cables arent running smoothly or pulling freely as it us to....am i supposed to get the cables changed...my husband tried oiling the system but that didnt help. please help me.
4 Suggested Answers
SOURCE: Can't figure out where wires go
Please scan the manual and post it here and I will give you clear instructions on how to assemble it. I have worked with home gyms for over a decade and know how to do it.
Patrick
Posted on Apr 22, 2009
SOURCE: need york mega max 3001 instruction maunal
I need an exercise chart for my york mega max 3001 multi gym.
I need it to see what exercises on that gym affects which muscles.
Where can I get one of these?
Neil
Posted on Mar 25, 2010
maxtreadmill
  • 832 Answers
SOURCE: i have a mega max 3001 multigym do i need to
The only thing that needs lubrication is the guide pole that hold the weight plates with silicone Napa or Pyrol brand is good and apply depending usage at least once a week. Procedure is use a cloth spray lubricant into cloth and rub cloth onto poles this clean and lubricate.
Posted on Apr 26, 2010
What is the height requirements for a york mega max 3001
This appears to be some kind of entertainment equipment - your query might be better directed to a forum dealing with such items.
Oct 05, 2016 | Cameras
Why is my 14 &20 chainsaw Model 8901/8902 having difficulty pulling cord. It seems to lock. What could be the problem?
if it runs ok after you get it started it could be the starter pulley. the blue max saws have that problem
Feb 10, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
I've pulled a Yamaha GT 100 out of the barn after a few years and the bike runs great except for this issue. When I gear down, the throttle sticks in a revved position. The kill switch will not kill the...
Hi,it would be best to undo the throttle cable where it gose into the carb then turn the throttle grip and see if the cable turns freely at the throttle grip,then pull it from the end that gose into the carb,if it runs freely then the carb needs cleaning,if it dose not run freely just replace it,hope this was some help.
Dec 22, 2017 | 2005 Yamaha Ybr 125
I have a mega max 3001 multigym do i need to grease the cables and bar that holds the weights.
Apr 26, 2010 | Ironman Exercise & Fitness
Need york mega max 3001 instruction maunal
Neil
Aug 23, 2009 | Exercise & Fitness
Yamaha motorcycle stiff clutch
Disconnect the cable at the engine. Does the cable move freely when disconnected? If it does, remove the left side cover then check the operation of the clutch arm. Does it move freely and spring back freely? If not then clean it up. If it does move freely, remove the clutch push rod from the center case. Roll it on a flat surface. Does it roll smoothly or does it sort of lope along. If bent, replace it. If rolling smoothly then put it back in the center-case and remount the side casing. Lube the clutch cable and remount it also. The adjuster #23 should be screwed in until it is snug then back off the screw 1/4 turn.
Assuming no one has tinkered with the actual clutch and it was operating properly a few months ago or when it was put up for the winter, now is the time for an oil change. Dirty, gritty oil can stiffen a clutch big time. Drain the oil and refill with 10w40 motor oil. No synthetics or oils with "special" additives or friction reducers. No oil marked ECII. Just normal motor oil. Shell, Mobil, Pennzoil, etc., the major brands. Ride the bike for an hour or so then change the oil again. Doing this will flush most all of the grit from the gearbox. Hey, oil ain't that expensive. This should take care of the problem.
A “very helpful” rating on this answer? Thanks!
Jul 01, 2009 | Yamaha DT 125 RE Motorcycles
Patrick
Apr 13, 2009 | Exercise & Fitness
Emergency brake
look under the front of the rubber boot that covers the bottom of the park brake handle, u will see a nut on the end of the park brake cable, tighten it until u reach the proper adjustment.
Feb 27, 2009 | 2004 Kia Rio
Exercise & Fitness Logo
Top York Exercise & Fitness Experts
Mikee
William McDowell
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
