Question about Ovens
My bottom element will no longer heat. the rest of the range functions properly. any suggestions?
  • 3 Answers
A model Number would really help but you might have a bad Element. Does your broil work, if not your control board could be bad.
Posted on Jan 02, 2011
The main oven doesn't heat but the main oven grill function does heat up! I'm not sure if this means the element is no longer working or if it is a problem with the control switch?
Make sure the power is off, then there should be two screws holding the element to the back wall remove them. Pull the element out until you can get to the wires, sometimes a wire will burn off at the connector, if that's the case replace it with a high temp connector if not disconnect both wires and do a continuity check on the element
Apr 14, 2015 | Ovens
790.9422340A LEFT FRONT ELEMENT WON'T WORK
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 19, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Changed my Oven element, now top and bottom don't heat up
The bake element
Feb 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Replaced oven element still not heating up
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
Feb 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
