Hp7280 ink failure code 0xc18a0201 can you help
I have an HP printer c6180 and am getting error 0xc18a0201
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Dec 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure 0xc18a0201 how do I address this issue e-mail address Lbenglish1@aol.com
0xc18a0201
Solution one: Reset the product
1. Without turning off the product, disconnect the USB cable from the rear of the product.
1. Remove the cartridges from the product.
2. Wait for the 'Insert Cartridges ' message to display on the control panel.
3. Disconnect the power cord from the back of the product.
4. Wait 60 seconds.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
6. Reinsert the cartridges, and then close any open doors on the product.
7. If you receive a prompt to print a calibration page, do so.
8. Reconnect the USB cable to the rear of the product, and then try printing again.
9. If you have completed all the steps listed above and are still experiencing a problem, you need to service the product.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | HP Photosmart C7180 All-In-One InkJet...
HP C7280
Hi there It worth a try nothing to lose and it may work. Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 02, 2010 | HP Photosmart C7280 Laser Printer
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart printer Ink System Failure Error 0xc18a0201 happens every time I start it.
You press the button to turn off the printer.
Unplug the power cord from the back of the printer. Unplug the power cord from the back of the printer.
Remove all the ink cartridges. Remove all the ink cartridges.
Wait two minutes. Wait two minutes.
Plug the power cord into the back of the printer. Plug the power cord into the back of the printer.
Press the On button to turn the printer on. You press the button to turn the printer on.
Install the ink cartridges when prompted. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the error code does not display, the issue is resolved.
Dec 05, 2008 | Computers & Internet
Says Ink system failure
Here are the steps that i want you to follow exactly to resolve your isse.
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. Thank you so much. adonscott
Jul 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink supply system failure on a d610 hp printer
hey I have a hp photosmart 8250 inkjet printer problem i need to know if I can fix from home myself are do i need to take it to a shop Error code: 0xc18a0201
Apr 25, 2008 | Office Equipment & Supplies
94 people viewed this question
k24674
