I have two T-42 think pads with the same problem. They will not boot. Message says "cannot find operating system". I have the IBM recovery disks. When trying to run them get message saying " problem on initializing" The hard drive icon/indicator light does go on either of the defective machines. It seems that I cannot acess the hard drive. Is the hard drive controller on the mother boards of the two defective machines burned out? What would be the fix. Replacement of the mother boards? I bought the two machines in an as is condition on ebay. I have swaped the hard drives around and can get recovery system to work in the third t42 I have that works. It seems
  • 51 Answers
It seems that the recovery disk u are using may be defective.Try to load os with another os cd.If every thing goes fine replace the recovery cd,otherwise it may be a defective motherboard.consult thinkpad service.
Posted on Jul 09, 2008
Sond device installer for ibm think pad type 1860 No 4 S/ NL9-KM 039 505
Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
May 08, 2012 | IBM Computers & Internet
Ibm think pad 240 x
There are many error messages that appear on your screen that make your heart flip, but I suppose the one that is certain to bring you out in a cold sweat is when you boot up your pc and a message appears saying Operating System Not Found!
You have good reason to get into a cold sweat with this error message because, nine times out of ten, there is a serious problem and that problem can be one of many, such as:
-The BIOS hasn't detected the hard drive
-You have an incorrect Master Boot Record
-The hard drive itself is damaged
Jan 28, 2012 | IBM Computers & Internet
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
My Think Pad Won't Boot Up When I Turn It On
Check the link given below for more details:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YLR6R
If you want more troubleshooting then provide more details like error message, what Operating System etc.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | IBM ThinkPad T21 Notebook
IBM Think Pad - ''Registry Cannot Load''
Ok so what you need to do is reinstall the Opertaing System. When system 32 files are missing then the Operating System dosent work. You would need to backup any stuff you need. If you have any other questions or need directions please email me at joegoetz16@gmail.com
Jun 05, 2009 | IBM ThinkPad R51 Notebook
I have an Ibm think pad laptop and I went to turn it on the other day and the ibm screen comes up with press F12 for bios set up on bottom but dosent go pass this screen no cursur and no sound got any...
Use IBM boot disc that was supplied with your computer. If that doesnt work use the operating system disc that came with it. If you have neither of those and the operating system was installed from the factory on a different sector of your hard drive try to start the computer up 3 times in a row and the computer should say safe boot or even boot from diagnostics etc. If you dont see any of that at all possible hard drive failure occured and you will be looking at gettting a new hard drive $50-$150 depending on size (newegg.com). Do you have the operating disc or not? if you dont then you will need to call IBM to see if they can send you a disc, if thats a no go then you will need to purchase one (newegg.com).
Jun 03, 2009 | IBM ThinkPad T40 2373 Notebook
Continuous windows xp startup failure
That's usually caused by a bad system driver. Next time it boots to the "start windows normally" page, select 'safe mode'. If the system boots well in safe mode, you can start from there by replacing the drivers from the system board on up until you've solved the problem.
May 07, 2009 | IBM ThinkPad T30 2366 Notebook
I just bought a used ibm think pad laptop
Hi there.
If you have just bought the laptop chances are the operating has been removed to you cannot see any data that used to be on it, you need to go and purchase a windows OS that the laptop was built for (i'm guessing XP) and re-install the operating system again.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | IBM ThinkPad R40 2681
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
