Question about GE Microwave Ovens
I dont know if i wire the white wire from my plug to the blue or brown wire from the disposal???
    Novelist:
  • 129 Answers
The microwave should be wired to a dedicated breaker. All the appliances in the kitchen should have dedicated breakers.
Wiring it to the disposal would be a code violation in most areas, and could be a potential fire hazard.
Posted on Jan 03, 2011
How do you replace the door switch for the door in the microwave oven?
Take the cover off, the switches should be pretty easy to replace. In the several I've done, they just snap out, unplug, and then snap back in.
Oct 25, 2015 | In Microwave Ovens
How can I obtain a service manual for KitchenAid microwave KHMS1850S,need wiring diagram to interlock switches.
Pulled up a schematic on this will try and help the first pic looks as though you removed the secondary switch the bottom one if so that is the wrong switch it should be a normally open switch that one is normally closed this switch goes up top on the other side of the primary switch the one with 3 terminals, look at the second pic the switch with 3 terminals that red wire in the wrong spot the skinny orange goes there the switch I just told you to put up top the red goes to one terminal the white and brown middle form the 3 terminal goes to the other terminal, the blue/white and blue go to the bottom switch this is a normally open switch if you don't know how to read a switch look at the switch look at com follow the line to where it stops if it is NO=normally open, NC=normally closed your primary switch is in the right spot you want the switch next to it to be NC and the bottom switch NO it blew the 20 amp fuse once you correct the switches and wiring and put in a new fuse if you have no power then it blew past the fuse and burnt out the filter board happens some times about 60 bucks let me know if this helps
Jan 25, 2015 | KitchenAid Microwave Ovens
Ive replaced the door switches & didnt write down the wiring sequence to put them back on.it is the lower switch & it has 2 switches & 5 wires to go on 6 pins.which wires go where
Every microwave I've worked on has a wiring diagram attached inside the cabinet. The wires are usually just long enough to reach one switch.
Sep 03, 2017 | Whirlpool MH2155XPS Microwave Oven
Hello, I am replacing the control panel on a Frigidaire Gallery Pro Series stove (it's a combo with gas stovetop and electric convection oven. Model: FCS388WECE Serial NF90100743 I am looking...
With the multipin connector on the right, the wire order is: (across the top, Left to Right): Brown, Green, White, Black, Yellow, Red (double), Blue, Black, Brown w/ White-Red Stripe. There are 2 Black wires which might be a problem... I have a schematic though. If you still need this info, reply to this post and I'll get it to you. Regards, Robert
Sep 13, 2011 | Microwave Ovens
The white wire on the inside of my nesco american harvest dehydrator is disconnected, where does it go?
The white wire either pushes onto the circuit board and or to the bottom of the heating element you will see another male clip that a white wire clips to as well. Could be either one of those.
If you would be so kind as to let me know which bundle of wires are wire nutted together I would appreciate that. I took mine apart to thoroughly clean it and assumed three black wires were nutted together. Much to my surprise I now see that there was one of two (don't know which one) blue wires that were wire nutted together w/those black wires. Then the other blue wire twists together with the other remaining blue. HELP!!!! Please :)
Sep 17, 2010 | Microwave Ovens
Wire Diagram
If the plug is not keyed and you cant tell from the wires, it probably doesn't make a difference. You are telling me it is 21 VAC ... AC dont care - and you dont appear to have a common ground situation.
Sep 07, 2009 | GE JE1460 Microwave Oven
Microwave blower motor wiring
I have an OH SUNG from a different model micro and have hooked it up every which-way I could and some how managed NOT to mess it up. I finally realized I needed the 6 microfarad capacitor across the RED and YELLOW. Works like a champ. ****** can move some air btw. I am thinking about thowing this puppy in my PC when I overclock it...
Maybe your VIOLET = BLUE and YELLOW = ORANGE?
Aug 19, 2008 | GE JVM1440 Microwave Oven
Thermador MBY microwave
The problem is the push-on connector on the UPPER door-latch switch; if the white plastic around this connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blade on the switch before reconnecting as the heat has likely left a burnt coating.
Mar 10, 2008 | Thermador MBYB Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
