Question about Maytag Neptune MAH5500B Front Load Washer
The washer is locked and has "do" on the screen.
I don't know if this is a solution but...
I too was just in your shoes. On a thread elsewhere on the site I found that there is a green fishing line that will release the lock hidden under the soap tray. (Remove it and then look in the pocket towards the front. You can reach in and pull out the line. Pulling it releases the lock)
Once the door was open. I unpluged the machine for a minute and then then closed the door making sure that it was snug.
I hit the On button and the machine went back in to a normal cycle.
We are currently waiting for it to finish. I plan on looking closer at the lock mechanism and see if it needs to be cleaned.
Posted on Jan 03, 2011
The screen displays the following: "It appears the door was not opened since the last cycle. If you would like to start a cycle, first open and shut the door, then press...
Judging by your comments I suspect there is likely to be a problem with either the door solenoid/lock or the door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 15, 2011 | Maytag Neptune MAH7500A Front Load Washer
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
The washer door is locked and the screen reads "int"...
Under the door there is a seam, there are 3 screws in that seam to remove to access that bottom panel. Remove the panel, reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
INT means that the cycle was interrupted. If you unplug the unit for 30 minutes it should clear when all the electricity drains out of the control board.
If it doesn't clear it means you may need to order and replace the front interface control board behind the control panel.
Feb 24, 2011 | Whirlpool Duet WFW9550 Washer
F22 error (in any washer setting) will not start, and cannot get door open. What "electrical "problem is this? Also, how do I get my clothes out short of using a crow bar on the front door!
F 22 is door lock error most likely need door lock but check door strike on door..To get clothes out remove lower kick panal reach up inside washer //at the bottom of door latch there is a small round tab pull down on it to release door..while you have the kick panal of there is a tech sheet inside washer try putting in die test/////but I would say door lock..Hope this helped If it did please vote...If you need more help please ask...Good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
