Pour climatiseur portable Maytag modèle MEP09D2A
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: J'ai un problème avec mon
Clean the air filter
Clean the evap coil
Clean condenser coil.
See if that makes a difference.
Posted on Sep 24, 2010
  • 251 Answers
SOURCE: i have a maytag portable air conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Je cherche le manuel pour operation du poele a granules Jamestown Pellet stove
Voici un lien où vous pouvez trouver des Manula du propriétaire de votre poêle à granules Jamestown. Cliquez sur l'onglet Support et vous verrez les manuels qui sont availabble. Vous aurez besoin du Modèle de Numbre à vous de choisir la bonne.
http://www.jamestownpelletstoves.ca/
J'espère que cela vous a aidé et merci d'avoir choisi FixYa.
Sep 20, 2011 | Heating & Cooling
J'ai pas le cd pour l'instalation
Sur cette page:
http://www.nvidia.fr/Download/index.aspx?lang=fr
Choisir le mod?le et le syst?me d'exploitation et apres vous pouvez t?l?charger le pilote pour votre carte.
Jul 01, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Code pour debloquer mobil telephone samsung s 5230
Salut, vous pouvez utiliser des codes pour d?bloquer votre mobile. il ya beaucoup de sites en ligne aujourd'hui, de fournir les codes de d?verrouillage. J'ai obtenu les codes de d?verrouillage d'ici
simpleunlocking
pour d?bloquer mon portable.
ici, ils demandent les informations suivantes sur votre mobile
mod?le mobile
pays d'o? vous avez apport? le mobile
fournisseur qui verrouille votre mobile
num?ro IMEI de votre mobile
puis finalement ils vont vous fournir les codes de d?verrouillage d?s que possible.
Jun 26, 2011 | Samsung SGH-S5230 Cell Phone
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
On me demande d'entré le
Vous pouvez essayer le code de restriction pour le téléphone Nokia 5220 Express Music Modèle mobile à ce site http://www.unlocking4u.com/nokia-5220-xpressmusic/rs6wp9/
Jan 19, 2011 | Nokia 5220 XpressMusic Cellular Phone
Mon PC portable ne connait pas digital camcorder VP D80
Avez-vous le pilote de votre caméscope numérique? Si vous installez le pilote. le pilote peut ne pas être compatibles avec Windows 7 et si tel est le problème que vous avez, faites un clic droit sur les propriétés du pilote et vérifiez. Changement dans les paramètres de compatibilité d'une ancienne version de Windows, puis accepter les paramètres. Avec cela, le pilote devrait fonctionner. Si vous n'avez pas le pilote, écrivez au fabricant pour le conducteur ou le télécharger sur leur site web
Jan 08, 2011 | Samsung VP-D80 Mini DV Digital Camcorder
Ecran noir
Le Fran?ais n'est pas ma langue maternelle, mais j'essayerai d'aider. Si l'?cran est noir et il n'y a aucune lumi?re sur l'affichage tel que la lumi?re de puissance, je v?rifierais la premi?re fois que le fusible n'est pas entr? dans la prise. Si c'est correct, alors essayez le moniteur sur un ordinateur ou un ordinateur portable diff?rent pour voir si c'est un manqu de la carte graphique. S'il n'est pas, alors je pense que le condensateur de puissance est entr? dans le moniteur et aura besoin repalcing
Dec 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Notice d'utilisation
Bonjour KRACOT, s'il vous plaît excuser mon français. Je me rappelle un peu le français d'il ya longtemps ..Vous pouvez télécharger le Manuel de l'utilisateur en anglais sur le site Kitchenaid à: : http://www.kitchenaid.com/flash.cmd?/#/page/home.
Cliquez sur Customer Care>Locate Manuals& Guides> et entrer le numéro de modèle de 6 caractères, dans votre cas K45SSW et sélectionnez le fichier correspondant à votre modèle qui apparaît sous Owners Manual (2 K45SSWH-0.pdf (2730.37 KB) et à sauver cette fichier sur votre PC.
Mai aussi vous voulez télécharger le fichier sous Parts List Manual (1) K45SSWH0.pdf (341.41 Ko). (Cocher Certainement pour voir ce qu'il répond à votre table de mixage).
La liste de pièces manuel fournit une vue éclatée pour le démontage et le remontage de votre console, avec tous les noms et les numéros de partie, au cas où vous souhaitez commander des pièces de rechange pour fixer vous-même la table de mixage.
Bonne chance. J'espère que ce sera utile afin que vous puissiez utiliser votre mixeur KA. Howard, Burke, VA, USA
Si cette solution a été utile, s'il vous plaît notez le, merci! hslincoln
Jan 19, 2010 | KitchenAid K45SS Classic Stand Mixer
?AINTENANCE
Salut, normalement la maintenance veut dire ceci : remplacer le Fuser, et les kits de petits rouleaux pour les bacs (Manual feeder et le bac 2, 3 etc) et le "registration roller". Toutes les pièces de maintenance sont faciles à changer normalement. Il faut contacter le fabriquant (ou votre vendeur de pièces informatiques) et commander le kit de maintenance pour le modèle de votre imprimante. Si ils sont gentils, ils vont inclure la marche à suivre dans la boîte pour comment faire chacune des opérations. Bonne chance!
Jun 09, 2009 | IBM Infoprint 1422 Laser Printer
Heating & Cooling Logo
183 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
