Question about Reddy Heater Tools 60,000 Btu Portable Kerosene Forced-Air Heater - R60A
I have a Reddy Htr Mod 60D kerosene-diesel heater. I need to know how to fine tune the air fuel adjusting screws on the back right by the air intake filter, and which one is fuel and air. The heater works great but seems to run extremely hot. More so than other ones I've seen like it. I know "if it ain't broke don't fix it" but I would really like to know the proper way to adjust them and what the factory settings are. Thank You; Sincerely, Alan Read
  • 674 Answers
You only adjust the one with the hole in the center. The other one is where you install an air pressure guage (0-15psi). The pressure setting is listed on the label of the heater (somewhere between 3-6 psi depending on the heater. All this is doing is controlling the air pressure/flow to the eductor that draws fuel out of the tank. Let me know if your label is wore off and don't forget to rate the answer and leave testimonial.
Posted on Jan 03, 2011
Testimonial: "rednitin:You know your heaters.That info is good to know. I have another ? so please read ur mail and let me no if I owe and how much.Thanx Al Read UT"
  • Brian Niten Jan 03, 2011
    I didn't see anything in my email Alan. I did see your other post though. The more pressure you have the more fuel flow you get. The less pressure, the less the fuel flow. The plug with the hole in the center has a spring and ball behind it. If you back the plug out, the pressure goes down because more air can bleed out of the hole in the plug. If you screw the plug in, it puts more spring pressure on the ball so it presses tighter over the hole inside, less air is bled off, and the pressure goes up.
  • Alan Read Jan 04, 2011
    Thank you so much redniten, you are a credit to your profession. If there is anything you need
    to know about concrete, farming or old farm equipment PLEASE send me an email or txt me
    @ 435 754 6420. Best of luck for the new year. Thanks again; alanr1711
Running very rich. how to adjust fuel and air screw
First of all are you running kerosene or diesel ? If you are using diesel, it does not burn as clean as kerosene which causes that burning rich smell. If you are going to use diesel, just use #1 diesel only but still may have a little rich smell. Don't use die red off road diesel. If you are using kerosene and want to check your air pressure on your pump, you will need a 10 lb. test gauge with a 1/8" NPT male pipe thread on the end of the gauge.There are 2 plugs on the back plate. Do not remove the upper plug with the hole in it. This is the adjustment screw for pressure. Clockwise increases pressure, counter clockwise decreases pressure. With the heater unplugged,remove the lower plug. Screw the test gauge in and start the heater. Check the pressure. Most are set between 5 1/2 and 6 lb. of pressure. Check your owners manual to see what your setting should be. If your pressure does not change, you have a worn pump and it would have to be repaired. Once you have the correct setting, unplug the heater, remove the gauge and install the plug back. If you feel that you are not qualified to perform this procedure, send it in to a local repair center.
Jan 11, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
100,000 btu reddy heater runs but smokes alot and you can smell raw fuel what's wrong
It sounds like the fuel is contaminated,if it is not k 1 kerosene ,or grade A diesel fuel,this could be the problem,clean the tank,and start with a k 1 kerosene,and see if it clears up,then go back to the grade A diesel fuel,if this does not work,replace the filter in the tank,and check the intake air filter,make sure it is not cloded up,or behind the filter,last thing ,only after checking and doing all of this,the pump pressure may need adjusting,but do not try this with out a pressure gauge,and a manual .You can break the pump easy.I have a manual for the ready heater,just let me no if you need it,please rate,thank yopu,> roniecon@gmail.com
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Diesel heater wont fire up no diesel geting to it
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 30, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R55 Wont Ignite
Fuel not a problem. Wrong pressure definitely a problem. Click here for instructions on setting the pressure.
Nov 20, 2008 | Reddy R70ET Utility Heater
Air fuel mixture screw adjustment, forced air kerosene heater
Most ready heaters have a fuel pressure setting on the back of the heater near the fan. There should be two small plastic covers, looking directly at the back, the one on the left can be removed and a pressure gauge installed. The one on the right is slotted for adjustment of pressure. I think the correct pressure for that model is 3.0 lbs.
Jan 06, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
189 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
