Question about Canon Office Equipment & Supplies
How do you put in a new toner? Randy - Canon Office Equipment & Supplies
  • 42 Answers
    What to Do
  1. Plug the power cords in, push the power buttons on and get everything up and running. Sounds simple, but lack of power is the culprit quite often.
  2. Check for a phone connection in the correct input jack. Some printers with fax capability have more than one phone jack so you can hook up an answering machine or another phone "downstream" from the printer. Consult your instruction manual to determine the right connection for your printer.
  3. Swap out the all-in-one printer for a working phone to find out if the problem is in the phone line coming from the wall. Once you hook up the phone, you should get a dial tone if the line is working. Remember to reconnect the all-in-one printer after you're done.
  4. Open up the machine and examine the feed path for the documents that you fax. Clear any obstructions you may find. Repeat this process with the paper tray and the path that copy paper takes through the all-in-one printer.
  5. Verify the fax number of your intended recipient. Also get your correct fax number out to the people who need it.
  6. Review your operating instructions and eliminate the chance for human error. Inadvertently skipping a step or misinterpreting an operation could be creating a problem that is simple to fix.
  7. Run through any system-specific troubleshooting regimen that is recommended by the all-in-one printer's manufacturer.
  8. please comment on my answer by voting or rating me
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Jan 03, 2011
Sharp machine printing blank afta i put new toner
That is usually a toner issue, try another new one or put the old one back in to see if the problem is with your new toner.
Jul 22, 2015 | Sharp Office Equipment & Supplies
Oki b6300 set drum toner cartridge, I replace the toner twice put it still give this message, and the new toner if i put it in anthor printer this message apper eventhough the toner is new and I tried two...
Press the Menu button
GO to "Admin Menu"
Select "System Settings"
Select "Drum/Toner Life"
Choose "Continue Print"
(press Feed/Select - which places a * next to the field)
press the Menu button again to exit
Feb 24, 2014 | Office Equipment & Supplies
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
Independent-supply toner message
Treat the same as "Non-Genuine Toner". Caused by installing a refilled toner cartridge or taking out cartridge out, putting a new toner, and then putting the old one back in. Place a new toner in the machine, change SP5-051-001 to 1, and cycle power.
Jan 12, 2012 | Office Equipment & Supplies
Printer is coming up with id mismatch after putting new toner cartridge in goes away when old one is put back in?
The toner for the 9035 has a 'chip' to identify the toner is correct for the 9035, ie the toner is the correct manufacturer and model.
If you are getting the "ID Mismatch" error you either;
  1. Have a faulty chip on the new toner cartridge, I guess the best option would be to go back to the supplier.
  2. The toner cartridge is a copy / refill etc and has the wrong chip fitted, again going back to the supplier would be the best option.
  3. Locate the contact for the chip on the new toner cartridge and ensure these are clean from any toner dust etc which may prevent incorrect contact with the printer.
Nov 22, 2010 | Tally Intelliprint 9035 Printer
Put in new toner still says toner needs replacement ? Using original Brother toner?
Brother says a standard toner cartridge will print about 3500 pages ... Things You'll Need: Replacement toner cartridge; Piece of paper ... Turn off the printer and allow it to cool for at least 15 minutes, if you have been using it recently. ... Put the new toner cartridge in the printer same way the old toner ...
www.ehow.com/how_6394835_change-toner-brother-mfc_8220.html
Jul 20, 2010 | Brother MFC-7220 All-In-One Laser Printer
Emty error with new toner. Oki B410
What a usless "solution"...Do you have something that can accually work?
There is a procedure that will solve this issue. I have a new toner inserted and it keeps crying that the toner is empty...I have taken in out and put it back in, Now how do I reset the **** thing?
Mar 06, 2010 | Oki Electric Industry B410D Laser 30PPM...
Toner exhaus/ toner replace
Put the new toner from sales (not from another new or Old printer)
Nov 20, 2009 | Samsung ML-1640 Monochrome Laser Printer
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Feb 11, 2009 | Brother HL 5250DN Laser Printer
53 people viewed this question
old marine
old marine
