Question about Cuisinart Coffee Makers & Espresso Machines
The grinder won't turn off. The only way to stop it is to unplug it.
  • 784 Answers
Sounds like a bad on/off switch -- remove and replace with alike switch.
c...
Posted on Jan 02, 2011
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Krups grinder 223
what problem do you have?
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
Ids77 electric coffee grinder I want replace fuse how can I open this prodact please.
see this causes and proceed:God bless you
Sep 25, 2012 | Coffee Makers & Espresso Machines
Machine won't turn off after grinding beans. have to unplug it and wait 20 seconds before repluging it to stop.
Just replace the relay which drives the grinder.
Thats all
You are good to go
Thanks
Please rate my work
Sep 10, 2011 | Bunn -o-Matic G2 (2 lb. Commercial Coffee...
I have Barista grinder. I've had grinder for about 3-4 years and it stop moving. I unplugged cord, tried to turn the feeder and plugged in still not moving except timer is clicking. I wonder why it...
Hi It could be the timer switch but if you hear the timer move(whirring) it is probably OK. There is a thermal fuse on the motor that will go out and you just have to replace the thermal fuse. Its under the wrap on the side of the motor. Which grinder do you have?
Jul 07, 2011 | Starbucks Barista Burr Grinder
Program light is blinking and will not turn off
Mak sure all pats are back together, grinder unti top to grinder unit, closed basket etc. If the beepin will not stop after that unplug unit for about 5 minutes then plug back in , once again making sure everything is closed. The beeping is to warn you that a part is not there and a leak is posible if tht the case. Hope that helps, Steve
Jul 28, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
298 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
