Question about HP Pavilion dv9000z Notebook
Battery problem Hello! My newly bought HP Pavilion dv9815nr has a bad battery. When i run Battery Check it says "Replace". I can´t charge the battery. What to do?
  • 76 Answers
You need a new battery HP have inbuilt protectors so that the computer wont get damaged so if it is telling you to replace the battery you should do it. Try and get it under warrenty If not just go into a computer store and ask for one that is compatable with it because if your warrenty is already void then you can put any battery in it.
Posted on Jul 09, 2008
How would I now if the battery is bad
Hello rrodri4330,
Welcome, and thank you for using FixYa!
To answer your question: The laptop itself will tell you that the battery is bad.
In any version of Windows, when you look down near your clock, you should see the Charging Icon engage and display; once the power adapter is plugged in. While this icon is displayed, you should see the percentage number rise, as the battery charges. If the battery remains at a low percentage, and never rises, then the battery is bad. That will be proof of your need to replace it.
I included a link below, from eBay!, to where to can purchase a replacement, cheap.
Battery
http://www.ebay.com/itm/8-Cell-Battery-HP-Compaq-Pavilion-DV7Z-DV7-1014TX-/250827506356?pt=Laptop_Batteries&hash=item3a667c02b4
Have a great day!
Sep 20, 2011 | Pavilion Laptop Battery For HP Pavilion...
Dv9815nr Entertainm​ent PC turns on for 5 seconds then turns off
I have to agree with them if you tested everything else. It could most likely be a mother board issue. It would benefit you to purchase another computer and not try to replace the mother board if its NOT under warranty. That MB will be expensive.
May 27, 2010 | HP DV9815NR Pavilion Laptop
I bought a replacement battery for my hp pavillion 6775us, and charged it and discharged it then charged to full and the battery check said i needed to replace it. it wasn't an HP original equipment...
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using fixya.
Kindly Let me know how it goes.
Hope this helps.
Feb 07, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion dv9815nr Entertainment Notebook PC turned off while I was using it and it wont turn on again.
Hello. I can assist you. Begin by unplugging the pc and then remove the battery. leave it that way for two full minutes as it resets. next reinstall the battery and turn it back on.
Dec 02, 2009 | Health & Beauty
My HP Pavilion dv8315NR PC Notebook crashes b4 windows even loads but has done this for awhile just shutting off think it could be the battery if theres a way to check?
there is a way to check whether the battery is good or bad , you can go to the hp.com and download the hp battery check software which is the smallest software into you computer and run the test it will show whether the battery is good or bad or whether you need to replace it.
Oct 27, 2009 | HP Pavilion dv8315NR Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Problem with my hp notebook battery!!!
discharge your battery compleately and then
charce your battery for 16 hrs add then discharge compleately
and charge till 100% batt level approx 2hrs
that will help
Nov 03, 2008 | HP Pavilion dv5020us Notebook
HP Pavilion dv9000z Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
