Question about Maytag Washing Machines
What is an sud error? I have no instruction manual that came with my washing machine and this is the first time I have seen a code apppear.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have too much soap in your machine, you should be using HE style soap. if you are you put to much in...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Won't finish the wash cycle
Initially we 1)used less detergent and make sure its marked 'he' . extra soap suds initiates error codes. 2) ran white vinegar with no detergent to clear suds 3) opened, checked and cleared trap.
Everything worked for a time but codes would return or like you would not finish wash cycle until water line in back of machine was made rigid so there was no chance of water or sud backup. So far so good. Good luck.
May 27, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Suds error
http://www.servicematters.com/maytag_library/docs/16025909.pdf
Here is the service manual for your machine.
When you get the suds cleared out you must use H E soap and or less soap.
You may need to run 3 or 4 cycles with no clothes at all to clear out the existing suds.
Mar 11, 2010 | Maytag Neptune MAH9700 Front Load Washer
I keep getting an error code of F35. I can find nothing that references this error code. Does any one else get it? Thanks for any help you can give me.
I haven't seen an F-35 error code listed on this specific model of Kenmore washer. I do see an F-32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition.
Be sure that you are using HE laundry detergent & the drain hose is not too low. Other testing will require accessing the internal components & making tests with a volt/ohm meter. If you have a meter & feel safe about making voltage checks.
Aug 30, 2009 | Kenmore Washing Machines
Sud error, door won't open, can't drain water
I was able to fix my washing machine thanks to helpful posts on your website. I didn't realize that the error code reference manual was inside the washing machine. I found the drain filter to be blocked by one of my childs tiny socks. After removing the sock and putting everything back together the machine worked fine. I am grateful that there are websites to help people that are willing to put a little bit of time in to fixing things around the house. I was on the verge of calling a service company to help me.
Thanks again, Medina422
Feb 03, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Error code 5d???
sure it's not sud? if so may be oversudsingbe sure you are using an he detergent if you are and suds are and issue try cuting back on detergent
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
SUDS error code
I suggest you disconnect the tube from the water level control pressure switch and blow it out well. Then, if need be, disconnect the drain hose and make sure it is clean as well.
Mar 13, 2008 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
