Question about Health & Beauty
I want to know how much is a 22kt gold king oscillator razor in a metal box and cardboard case with pack of razors and direction vintage Thank you.
Varies from 'free' to approximately $35.00. Problem is finding decent blades as they are unique to the razor. Also - some report poor shaving experiance... Still - a very unique and intersting device! ...take a look at e-bay for examples and price range; mine was given to me by a friend that had no use for it.
Posted on Jul 22, 2015
SOURCE: Braun Shaver 4615 - User Manual
countour 5790 instructions for cleaning
0
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Posted on Oct 14, 2008
  • 12 Answers
SOURCE: Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Posted on Aug 11, 2009
brector3
  • 1610 Answers
SOURCE: cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Posted on Jun 04, 2010
brector3
  • 1610 Answers
SOURCE: disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Posted on Jun 13, 2010
What is vintage razor
That means a very old razor.
Apr 07, 2015 | Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
Is it necessary to hone a straight razor?
All razors lose their edge over time even with daily stropping. Honing reestablishes the fine edge of the razor by removing some of the medal some of the metal from the razor. Honing is a necessity when it comes to razors.
Battery will not hold charge
Go to Wal-Mart Electronics dept. and buy a DR9576 Digital Camera battery pack for $14.00, then pry at the seam between the front and back parts of the razor after removing the trim head, dust collector cup, and beard rake assembly from the top of the trimmer and separate the two halfs of the razor. This should allow you to easily remove the battery holder-circuit board-charger plug assembly and pull outthe battery pack which consists of two NiCad batteries which are glued together so as to have opposite polarities next to each other. Carefully using a flat blade jewelers screwdriver, pry the metal tabs off of each end of the batteries and take the DR9576 battery pack which is already joined together in the same configuration and place the flat bar tab onto the end of the pack. Hold the battery holder with the wired side of it facing down, and carefully insert the end of the battery pack you just set the bar style tab onto in the end that has the charging plug closest to it so as to have the plastic "springs"
holding the metal shorting tab {flat bar tab} up against the battery pack. When you do this, be sure to align the battery pack so as to have the other end positive terminal lined up with the red wire with the metal tab on it. As you insert this end of the battery pack into the holder, insert the metal tabs with the wires on them in between the batteries and the plastic holder so that they are pinched up against the ends of the batteries. If you did this right and didn't let the tabs fall out of place, you now have replaced the old batteries with a pack with almost twice the storage capacity as the originals had. Reassemble the razor in the reverse order that you took it apart in and plug the charger into the razor for approximately 36 hours for the initial charge. Also these batteries are NiMH which do not suffer from battery memory which means that they do not have to be nearly dead before they can be recharged in the future. your trimmer should now be fully functioning after complete charge for the first time and should give you years more service while holding the charge for in incredibly long time. Congratulations!!!
May 11, 2011 | Norelco T770 Beard Trimmer
Could the comfort strip with aloe and vitamin E in my schick silk effects plus razor blades be causing the horrible rash I have on my legs?
It may however if you used the razor multiple times its more likely a fungal rash. No its nothing major to fret about it happens to the cleanest of clean folks! Try using an anti-fungal cream such as lotrimin to clear up the rash and making sure your razor is dry when done cleaning it after use!
May 08, 2011 | Schick-Wilkinson Sword Schick Silk Effects...
NEED TO KNOW HOW TO OPEN NORELCO T770 ACCUVAC TO REPLACE BATTERIES
Mar 20, 2011 | Norelco T770 Beard Trimmer
We have A 300 razor battery scooter but do not have the battery pack or the charger.
Buy a replacement battery pack and charger at razor.com or http://electricscooterparts.com/razore300.html
Jul 10, 2010 | Razor E200/300 Electric Scooter Battery
Norelco razor 6867xl - am planning to replace battery pack. Would be easier to solder if I could remove the whole circuit board system from the hard plastic case. How do you release the metal clips?
The whole circuit board is removable, and I would recommend removing it from the whole external case to work on so nothing is damaged by your soldering iron.
Battery : 2x NiCd AA
Battery capacity : approx. 700 mAh
May 20, 2010 | Vacuums
Health & Beauty Logo
251 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
