Conia LCD Model CLCD3250D... Won't switch on at on/off switchon set or on the remote. BUT will come on when both ON?/OFF switch and Channel switch on top of set pressed at same time. Then get split screen with picture which then goes off and red lettering appears on left side : With X Power....DEMO mode (Exit Power off) On right side of screen...Without X power.......Buttons on top of set not operating properly or remote not working at all (new batteries in remote)....Switching on & off makes no difference.
SOURCE: ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
Posted on Mar 12, 2008
SOURCE: Acer AT3201W LCD TV
I repaired my Acer by replacing the power supply from
http://www.power-on.com/lcd323-4m.html - $85
Acer would not sell me a replacement power supply.
Note: I needed to solder wires the new power supply to the old one,
the pinouts on the connectors on the new one would not fit the original.
Posted on Dec 13, 2008
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
I have a CONIA clcd3250d TV but no remote and the
What is the problem you faces with this TV? Provide more details please.
Feb 24, 2013 | Televison & Video
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Why won't any universal remotes work with my LG tv?
The two possible reasons are:
1. None of the codes are correct for this model.
2. The remote infrared receiver in the set is bad.
(maybe the reason the other person got rid of the set?)
There are some ways around this depending on how you hook up and what you have for signal:
If a box (cable or sat) is connected to one of the sets of audio/video jacks on the set--switch to that input and change channels etc with the box!
Use the box remote for functions like channel and sound etc.
May 01, 2012 | LG 26LG30 26 in. LCD TV
Conia 32" LCD TV will
Good day!!!
please try to set auto scan..
just go to the menu using remote control then go to the settings and find auto scan..
please complete the 100% scan for better results..
thanks for using fixya.
have a nice day!!!
Jun 30, 2011 | Televison & Video
Hotel lock, not available but im sure there is another way
Not all sets have a hotel lock.....key in for a google search on the model and get a free download of the user manual.
May 20, 2009 | Sansui HDLCD3210 32 in. LCD TV
Universal remote codes for a conia tv?? Help me PLEASE :)
Thank you guys! just bought our universal remote control and now we able to use 1 remote for everything especially our conia plasma tv and it really works the 0821 code...
Mar 05, 2008 | RCA Universal Remote Control
Remote control set up /
you likely need to go into the menu and set it for cable then autoscan the channels to have them stored so you can switch through them.
Feb 17, 2008 | Televison & Video
Conia tv remote codes
I have a Conia LCD TV and the remote died, I purchsed a universal remote and without the codes even on search modes could not get it to find the t.v. I found theat DJ Electronics sell replacement Conia TV remotes online. So if you just need areplcement remote, know your TV model number and you can just replce your old remote.
Jan 21, 2008 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
