Question about 426P 460HP Security System - 426P
Disable valet mode on python alarm? - 426P 460HP Security System - 426P
4 Suggested Answers
injunearing
  • 81 Answers
SOURCE: The valet feature is set on my Python CE0890
here is a link for the manual
Posted on May 30, 2011
  • 55 Answers
SOURCE: i can't find a valet switch for my python 460hp?
you can find the "brain" by tracing the wire from the LED blinking light to the brain than look for a grey and black wire which is the valet switch. Don't look for a toggle switch either, your looking for a little black button not a silver toggle but a little black button. Depending what vehicle you have also matters, for instance if you have a GM truck look in the side dash fuse panel or look BEHIND the hood latch handle. It's a ***** to find sometime but essential that you know both where it is and what it does and how it works.
Posted on Aug 08, 2009
  • 6 Answers
SOURCE: HOW TO DISABLE PYTHON ALARM SYSTEM WITHOUT DISABLE
When the remote start is disabled with the Toggle switch there is no reason why the door locks should not work. Sounds like faulty installation.,
Posted on Jul 16, 2010
Is 448V remote compatible with Python Car Alarm?
if its lit solid that usually means a problem with the system... so the alarm portion is most likely not active... or it might simply be in valet mode... without knowing the model of your car that's the best I can offer...
May 05, 2016 | Python Vehicle Parts & Accessories
Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
Aug 21, 2012 | 1995-1997 Chevy Tahoe Ignition Starter...
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
I lost remote, cannot start car and alarm keeps sounding
yOU CAN ORDER A REPLACEMENT REMOTE ONLINE FROM DIRECTED. IN THE MEANTIME YOU CAN PUT THE CAR IN VALET MODE TO DISABLE ALARM TEMPORARILY.
Jun 10, 2011 | 426P 460HP Security System - 426P
I lost my key with the python remote on it and when i use my spare key i cannot turn the alarm off what do i do.
The python alarm has a manual alarm disable. Upon entering the vehicle, turn ignition on, press and release valet switch. You should hear two chirps confirming that the alarm is disabled. Start the vehicle.
Oct 09, 2010 | Python Vehicle Parts & Accessories
I believe that my alarm is in a type of sleep mode how do i wake it up?
Turn ignition to the ON position, press your VALET button till the LED light goes out.
Aug 13, 2010 | Python Vehicle Parts & Accessories
How do I get the car alarm out of valet mode?
leave a door open then turn ignition on then off and push the valet switch one time within 10sec
May 23, 2010 | 426P 460HP Security System - 426P
When i bought the car it was disarmed maybe cause it was towed?
Do you have the alarm's remote fobs? If not do you know where the valet button lives? It's a little black button hid somewhere under the dash. Anyway put your key in ignition turn key to "run" position and within 5 seconds push the valet button and that should stop the alarm and allow you to start the vehicle. OK after you get the vehicle started turn it off and hit the valet button again. The blinking LED should be solid not blinking and that's telling you your in valet mode which means the alarm is off, the conviencince features like keyless entry and remote start will still work but the alarm is standing down.
Aug 11, 2009 | 990 And 950 Responder SST Remote - 7701P
I want to diable the alarm without,not the door locks It is a (Python 426P 460HP security system)It does have a remote.Thanks
Locate the valet override/program button. Turn key to "run" position, push and hold button for a couple seconds, and that should put it in valet mode. Door locks will still function with remote, but alarm will not arm. LED should stay on solid.
Apr 22, 2009 | 426P 460HP Security System - 426P
426P 460HP Security System - 426P Logo
471 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
