Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Unable to switch on tv - Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
  • Toshiba Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 02, 2011
I AM UNABLE TO CONNECT USB ON MY SAMSUNG LCD TV MODEL NO.LA40D503F7R
you need to switch the input to USB from antenna or cable probably
Sep 14, 2015 | Samsung LA40D503F7R 40 Full HD 1080P...
Unable to switch from tv to cable Magnavox older 13
Have you tried accessing the on screen menu and maybe changing the input type to cable or even line in if you are using rca (red/white/yellow) plugs to connect the cable box to the television?
Oct 19, 2012 | Philips Magnavox 20MT133S 20" TV
Have a Viewsonic LCD TV N4790p and currently unable to switch tv on. the standby light flashes blue every 30 seconds to a minute and the TV is unable to switch on. there is sound coming out but no picture.
Hello antlisa02:
First lets try a hard reset, that means unplug your tv from the outlet thats providing power to your set. Leave it unplugged for at least a couple of minutes. Plug it back in and hopefully your TV has reset itself.
Other than that you might have to have it professionally looked at.
Here is a link for your manual, maybe it might help you.
"CLICK HERE"
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Mar 26, 2011 | ViewSonic N4790p 47 in. LCD TV
We have a philiips dvd recorder, but unable to
switch tv to the input mode you have conected dvd to e.g ( AV or EXT ) if dvd is a recorder one have you put areal in back and tuned in dvd recorder
Nov 28, 2009 | Philips Televison & Video
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Unable to get remote to switch to tv/video RCA remote tv is sanyo
It took me forever to figure it out. Press the input key, just below the 9. The TV channel should be on 3. Make sure you put your DVD in and press play manually, so you can see that it is on.
Hope that helps
Apr 03, 2009 | RCA 3-Device Universal Remote with...
Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Dec 21, 2007 | Televison & Video
Sharp LCD 20" LC-20SH1E
Can you tell me how to adjust the picture size on the above tv? I switched it off one evening and when i switched it on again I was getting a broad black line at the top and bottom. When I put on the teletex I can see the tv picture down the right hand side of the screen. I have been through all the buttons on the remote control but am unable to fix this.
Nov 11, 2007 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
595 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
